Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
2264 Soru Tümünü görüntüle
iPhone Stuck in White Apple Logo.
My iPhone Stuck in White Apple logo. I tried resetting the iPhone , Also Tried restoring the iPhone Multiple times even in DFU mode also. Restoration was successfully completed but device is again showing the same issue. Iphone is stuck in Apple logo itself. in iTunes device is detecting . Device is not under Apple Coverage and i believe if i visits Apple Support then they will advise for a whole unit replacement only. Kindly advise is there any solution for repairing this issue.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
It seems like a bootloop.
Your iphone have problem with the new update, you can download a diffrent version of ios and downgrade it. The new update maby have a problem, and apple will fix it in time, until then you can try do plug your iphone to ituns, go to recovery and download a older version of ios. Like if you have ios 11.3 you see if you can download ios 11.1 or 11.2 and see if your problem is solved.
Bu yanıt yardımcı oldu mu?
Puan 1
4 Yorum:
Will it be possible to downgrade. My IOS version is 11.2.5. Kindly advise whether i can downgrade the same?
tarafından
Here you have a link to ios 11.1
Hope it work out for you!
tarafından
It is not allowing to installed since the IOS is not signed by Apple. Downgrading is not happening.
tarafından
Yorum Ekle
You can easily try this: How to Fix iPhone Can’t Turn On & Stuck On White Apple Logo When Rebooting?
Puan 0
1 Yorum:
Of course this site is verified, it is free and reliable. But you may not save your date. did you backup your device on iTunes before?
tarafından
Yorum Ekle
Yanıtını ekle
HASHIR ABOOBACKER sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,429
