Ana içeriğe geç
Released in June 2012 and has a identified by model number of S5312. This device has a silver textured plastic cover with the Toshiba logo centered on the back of the 15.6 inch screen.
7 Soru Tümünü görüntüle
What charger would be compatible with this laptop?
I've been doing some research but can't seem to find a charger that specifically goes to this laptop. I don't want to run the risk of ordering a product that doesn't work or having to pay for the expensive one on the Toshiba website. Would it be possible I can be provided with a link to a seller or brand that is compatible?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If you just search eBay for "Toshiba Satellite P855-S5312 charger" you should easily find one that is suitable. Chargers are normally compatible with a range of laptops, sometimes a very wide range. The only things you need to be sure to check are:
  • The plug that plugs the charger into the laptop is the right size. If a charger is advertised for your model it most certainly should, or you can send it back and complain.
  • The voltage is correct, in your case I think 19V, but it should say on an identification label on the bottom of the laptop.
  • The power in Watts (W) or the current in Amps (A), which again should be specified on the label on the bottom. (Watts = Volts x Amps so don't worry if only Watts or only Amps is specified.)
  • The mains plug is suitable for your region.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Monica Taylor sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 95
