How do you fix a broken right hinge on Nintendo DS light?
the right hinge it not connected to ds at all
[<img src="https://i.ytimg.com/vi/7yA9yXBNiro/hqdef... alt="Image result for broken ds lite"/>|broken ds]
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi Elizabeth,
I have repaired DS and DS Lite systems with similar issues. To repair the hinge, you must either replace the small, ball-shaped joint and its pin
of the shell or do a complete shell swap
If you are new to the repairing scene, I would approach this repair with caution as it would be challenging to repair without much experience. However, with patience and a close adherence to the guide included below, you should be fine. To begin, I would recommend doing a full shell swap on the console. The work required on the system for either method I listed above is nearly the same. In addition, I doubt that you would find a listing for just the center piece. To replace the shell, you should follow this guide. I hope my answer helped. Happy fixing!
Bu yanıt yardımcı oldu mu?
If the DS lite doesn’t power up after charging there is probably something else wrong than just the hinges, correct? I did notice one of the hinges were attached to a wire? Any instructions for that side?
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 39
Her zaman: 4,220
