Ana içeriğe geç
External storage options by Seagate, usually connected by USB, available in many storage sizes and form factors.
44 Soru Tümünü görüntüle
How to remove hdd from a Seagate 4TB expansion drive and access files
I have a 4TB Seagate expansion drive (long out of warranty) which was knocked off a table and will no longer power up. Can someone walk me through the process of removing the hdd from the expansion case and setting up an hdd reader to let me access the files?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
@mapiper any model on this drive?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
See if this guide will help you figure out how to get the enclosure open:
Seagate 5TB External USB3 Teardown
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Cracking open the case won't help you to gain access to the files as it sounds like the platters and/or heads are in trouble here. I'm assuming the case its self is not damaged (the port and power connectors are intact).
At this point I think you're going to need to ship the drive out to a recovery service if the data is still important. It won't be cheap ;-{ Data Recovery Services
Backing up is so important! I even back up the back up ;-}
Puan 0
Yorum Ekle
Yanıtını ekle
Michael Piper sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 27
Her zaman: 1,737
