Ana içeriğe geç
This is an older equipment line from Saeco. All are labeled Sup 018. (Badge on the bottom). They were later sold under the name Spidem Trevi
10 Soru Tümünü görüntüle
Starts to brew, dispenses abt 2oz liquid, stops, red lights comes on
My SAeco has been cleaned to the best of my ability, having taken apart the brew unit. Still it only dispenses about 2 oz of coffee, no matter the setting, and then stops, and red light comes on. Never brews more than that amount. Reset is , start over, same result.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Hi this video might help you out or at least point you in the right direction.
Vienna
Bu yanıt yardımcı oldu mu?
Puan 0
2 Comments:
Thank you, but nope. None of that addressed my question.. Coffee maker seems to be going through all the functions properly, but no matter what setting I put it on, it still only dispenses about 2 oz of water, then stops, and the red error light goes on. No help directly from Saeco, and to have it repaired I would have to ship it out of state, pay for the repairs, plus shipping to and from...Way too costly, even for a $500 machine.. Very disappointed with Saeco. Second problem I have had with it. First time it was still under warranty. This time not. I've tried everything. Guess I ll have to stick with my trusty backup...a Keurig.
tarafından
OK have you run it through a descale programme yet? You can either get the correct 'cap' and run your descaling tablet, or use a bit of baking soda it does the same job, but messier. You could also try running straight white vinegar in the water reservoir. Then set it to the preheat cycle and the vinegar will dissolve any scale present. I'd try the descale tablet first though. That would be one of the only reasons for it not dispensing enough water. Either to much scale, or literally caked with crud. Have you had your head unit out to clean the coffee grounds out of it?
tarafından
Yorum Ekle
hi have done every thing and its still not working
Puan 0
Yorum Ekle
The Vienna doesn’t have a low water sensor on the water tank. It uses the flow meter to determine if it’s out of water. Try running test mode see https://www.youtube.com/watch?v=Ng-zQurY... and see if your flow meter turbine is working correctly. If the red light comes on and stays on, then it’s probably this problem, the vienna thinks it’s out of water. You could also try to prime the pump after the red light is on by turning the knob on the right side of the machine to see if you get water. Another thing you could try is after turning on the machine, turn on the water knob to see if you get about 2 ounces of water then the red light goes on again. If that happens, it is likely the turbine flow meter that’s faulty. In this case, it could also be the controller board.
Puan 0
Yorum Ekle
Yanıtını ekle
ron.costa sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 1,027
