Wobbly ceiling fan noisy
Ceiling Fan blades make noisy and seem out of balance. How to repair
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Contact the manufacturer to get a balancing kit for your fan. They often have a set of weights and a special level unit you place on the center of your fan then you carefully apply the weights to balance things out.
I suspect in cleaning you knocked the weight free or sucked it up in the vac.
Bu yanıt yardımcı oldu mu?
A ceiling fan must be well-aligned to be balanced. Be careful doing so because you can be injured by the fan, or you can fall off a ladder. Perform these steps in the order shown and stop when the fan is well-balanced. All steps may not be necessary.
# If the fan requires additional balancing, slowly move a piece of chalk (or a tightly folded cloth with flour on it) from the outside of the spinning blades toward the tips until the first blade strikes the chalk. Stop the fan and locate the marked blade. This is the “heavy” blade OR the blade opposite it is the “light”blade. You can take (and perhaps repeat) several steps that can help correct the imbalance.
Give yourself plenty of time and you’ll be pleased with the rock steady fan.
I have a set of three ceiling fan blades, which have got few bends. How do I recondition it?
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 1,090
