Ana içeriğe geç
The first Altima was produced in June 1992, as a 1993 model. All Altimas were built in Smyrna, Tennessee, until June 2004, when Nissan's Canton, Mississippi plant also began producing the model to meet high demand.
My car died at the intersection and now wont start
My car just died at intersection I turn the key and it just makes the rrrrr sound but doesnt turn over i thought might b crank shaft position sensor but no luck can u plz point me in the right direction
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
When you turn your key to the ign position, where all the lights on the dash are on but you haven't started it yet. Do you hear a buzzing noise coming from the back? If not, check your fuel pump fuse. If it is broken/blown like in this picture then pull it and replace it with a fuse of the same rating. (colour). Should be spares in the fuse box. Usually on the back of the fuse box lid will be a list of the fuses and what they do, their numbered location and their rating. E.g. 15 amp is 15A.
If you change your fuse and you turn your key on again only until all the lights are on the dash and you hear a buzzing it should start.
If not the fuse, then assume your fuel pump is dead and will need to be replaced. Sometimes you will hear the buzzing and still no go. Could be a lack of pressure issue. If you change your fuel pump always change your fuel filter, it will be old and dead by now.
Let us know how it goes.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Cassandra sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 438
