Ana içeriğe geç
Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794 Soru Tümünü görüntüle
Setting up new SSD
My original hard drive crashed. I have a backup on a Seagate external hard drive. I installed a new Crucial SSD and am having trouble formatting the new SSD with the operating system. Internet recovery has not helped. How can I format the new SSD without the old hard drive?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
It maybe the real problem is the HD SATA cable is worn here Vs a bad HDD.
All of the 13" Unibody MacBook Pro system's have a problem with the cable abrading against the uppercase. Here's the IFIXIT guide to replace it: MacBook Pro 13" Unibody Mid 2010 Hard Drive Cable Replacement You'll want to place some electricians tape on the uppercase were the cable rests to protect it. The other thing here is Apple updated the cable on the newer system. Here's the cable you want: MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable. The shape is a bit different and you can only mount one screw on the bracket but thats OK.
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable Görseli
Ürün
$34.99
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
To install your OS onto your SSD you'll need to create a USB thumb drive OS installer. Lets see if we can get your HDD running here externally using this SATA to USB adapter: Startech 2.5" SATA to USB adapter. You'll need to reformat the SSD as a bad cable tends to corrupt the boot sectors just enough things could go bad later on. You'll need to use the Option key to get to it to boot up. Follow thins guide: How to create a bootable macOS Sierra installer drive. Apple is still having issues whit the new file system (APFS) in High Sierra on SATA based SSD. As such I don't recommend using it yet. It's great on the newer PCIe/NVMe drives! Good Luck
Reference: Mac startup key combinations
tarafından
Once you get your SSD going you may want to reformat your HD and get an external case for it. An extra HDD is always useful.
tarafından
Yorum Ekle
If for some reason you can’t format your SSD via “Internet Recovery” mode, you will need though an additional laptop or desktop (either one) to go into “Target Disk” mode. There it will allow you to format it there.
Puan 0
Yorum Ekle
Yanıtını ekle
ross mcleod sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 1,640
