Ana içeriğe geç
1986'dan günümüze Harley-Davidson Sportster motosikletler.
Strange sound from my engine
Hi guys, i bought a sportster 883 r two months ago and i knew from the mecanic that the guy i bought it from, had a failure in the oil pump and he drove 15 miles, the mecanic said he changed the pump and one from piston head. But a tic tic sound is coming from the engine and the sound becomes higher when i drive long distance, anyone can help me what this sound may be???
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum:
I recently figured a new problem every 40 miles my rear spark plug is fouling is it related to the ticking sound??
tarafından Paylaş
Quite possible, is it oil fouling? If so your lifters may need adjusting, and if they are auto adjusting, you may need to replace either your chain/belt, slipper/tensioners. Does it blow a bit of smoke on start up, or when taking off from traffic lights. These are indications of valve stem seals and or valve adjustment.
tarafından Paylaş
Yes, it is blowing smoke on startup.
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
Tic ticking sounds are usually lifters. Or noisy valve train. I'd personally take it to another mechanic, don't tell him the story. See what that guys says it is.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
It could be anything really, as the engine may need a full rebuild.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Johnny Chebel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 1,315
