Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
2264 Soru Tümünü görüntüle
help - home button :((((
Guys, please I need an urgent help :(((
I got an iphone7 with broken display and it was changed, but now the home button doesn’t work anymore. I asked to change the home button but still not working.... I’m trying to access the phone but it’s on the “press home to open” and it’s not possible...
Is there another way to access the phone without the home button? What should I do? :(((((
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I'm not sure on accessing your phone but it does sound like when the screen was replaced the home button ribbon cable was damaged.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I hope you still have the original home button! the 7 will not work with any other home button each button is unique to the phone. if you have the original home button try it on another new screen because sometimes the connector on the screen is bad. hopefully you haven't damaged your home button flex.
Puan 1
3 Yorum:
I think that the original home button is damaged... I know that any other button won’t replace the touch ID, but I thought that the home button would still work... Do you sth about this? It should work, even without the touch ID, right? I really need this phone to work
tarafından
I added pictures
tarafından
no all the iphones it will work as just a home button from 7's and up it will not work at all. I see yours is damaged there is a chance you can get it to work by getting the chip switched to a new button.
tarafından
Yorum Ekle
Yanıtını ekle
Maiara Fontana sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 138
