Ana içeriğe geç
Stylo serisinin ikinci modeli olan Stylo 2 (model numarası LS775), LG tarafından üretilmiş olup ilk olarak Nisan 2016'da piyasaya sürülmüştür.
Sound is not working
I only have sound when using headphones. How do I get my speaker to work?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
3 Yorum
I have to same problem it say my headphones are in but they are not
tarafından
It shows headset logo on screen and sound is not working
tarafından
I am having the same problem with my LG Q Stylo+. If anyine has anyrhing to help please contact me at aedanouellette@gmail.com
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Tried various fixes I found online for the same problem with my LG Stylo2. This is what worked for me....Remove the back cover of your phone and push on the speaker (left bottom) a few times. All of a sudden I have sound again. Loose wire likely cause inside speaker!! Hope this works for you.
Bu yanıt yardımcı oldu mu?
Puan 7
9 Yorum:
Thank you!!... I tried all sorts of things to get my speaker working again!... I almost did a factory reset on it.. Who would've thought something so simple would work! Lol.... Thank you again for your advice!
tarafından
Thank you! This worked.
tarafından
I am so glad. Did not know if this would last but 4 months later and mine is still working with no problems. Glad I could help.
tarafından
It worked for me too!!!
tarafından
and anotha one!!!!
tarafından
4 tane daha yorum göster
Yorum Ekle
You got to take the back off and screws out take off souronding plastic molding there is 2 pins connected on the speakers itself they must be touching the tape or ribbon perfectly or you will not get sound go to YouTube for video on how to take phone apart properly
Puan 1
Yorum Ekle
Had the same issue took it all apart & put it back nothing, sprayed the contact cleaner ,pulled the speaker out tested it outside it was good, then i saw where the speaker sits if you push the cover you'll hear a click that is the notch that pushes the cover & makes the contact.
Puan 1
2 Yorum:
thanks so much i try this way my problem was resorve .
tarafından
The push and click worrrrrked! Thank you so much!
tarafından
Yorum Ekle
Puan 0
Yorum Ekle
Pushing of speaker repeatedly from left to right or from right to left by removing just back cover
Puan 0
Yorum Ekle
Yanıtını ekle
Geneva Campbell sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 29
Her zaman: 13,165
