Ana içeriğe geç
In June 2017 Apple updated its 13" MacBook Air with a newer Broadwell Intel Core i5 processor, resulting in slightly increased performance and battery life.
Very dim screen after damage?
So about six months ago I accidentally dropped a glass of water on my Macbook and I took it to my local apple store and they told me it had water damage and needed massive repairs and I should just buy a new one because it would be cheaper, I didnt have the money for that so I took my broken laptop home and left it in my wardrobe for six months and the other day I was cleaning out my wardrobe and found the charger for the laptop and wanted to sell it but didnt know if it was workable as it got slightly wet in the water incident, I thought maybe I could plug it into the broken Macbook even though it doesnt work maybe somehow it would work and upon plugging it in the charger lit up! and then I left it for a good few hours to charge and when the charger went green I tried turning the laptop on and it worked but the screen is extremely dim, I was wondering is this an easy fix? or am I going to be told once again that the water has damaged it too much for it to be under $300? thank you for your time :)
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Try f2 or fn f2 on your keyboard. If that doesn’t help you can try removing the back cover and check led cable connection make sure it’s clean.
Bu yanıt yardımcı oldu mu?
Puan 0
4 Yorum:
Are you talking about the bottom of the laptop? remove that? and how to I know what the led cable is?
F2 and FN F2 didn't work.
tarafından
Yes, remove the bottom cover. Led cable should be by bottom left hinge. It is a large flat cable with about 30 pins.
tarafından
This job requires a torx t5 screwdriver. Do not attempt to open it with any other tools as this could damage the screws.
tarafından
torx t5 doesnt fit into the screws.
tarafından
Yorum Ekle
Yanıtını ekle
Jenn peg sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 233
