Ana içeriğe geç
Signal failure, original imei
My M9 cell does not receive or make calls, it is original imei, it connects to the normal data network, and the pc does not recognize it even though it has the drivers installed.
Mi celular M9 no recibe ni realiza llamadas, es imei original, se conecta a la red de datos normal, y la pc no lo reconoce a pesar de que tiene los driver instalados.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Check if the Imei is blocked. Not sure what the best website is to check the Imei number.
Usually second hand, or found phones may have a blocked imei. Pretty common thing.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
The imei is not blocked, so check it out. It was a bad flash. But now I do not know how to repair it does not connect to the pc. (the pc does not recognize despite having the original drivers installed).
tarafından
You will need to reflash firmware using the info shown on this page:
http://forum.gsmhosting.com/vbb/f485/htc...
I haven't flashed HTC firmware in a long time, but I know it's a PITA to do it compared to Samsung and iPhones.
tarafından
Yorum Ekle
Yanıtını ekle
Percy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 534
