Ana içeriğe geç
Ekim 2014'te piyasaya sürüldü. SM-G530H/DV model numaralı bu Samsung Galaxy Grand Prime; Beyaz, Gri veya Altın renkli bir kasaya sahiptir.
Not able to unbrick properly
So I have been trying to unbrick my samsung galaxy grand prime phone for a while and every single time I try on Odin it gives me a fail, eventually the phone turned on with all my data. I want to factory reset the phone but when i tried it went unto the brick state again. The phone at the moment is slower than I remembered.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Where you you performing the factory reset?
If you are trying to do it via Settings > Backing & Reset > Factory reset, then try the other method below.
Turn the phone off. Or just hold volume down + power + home until the screen shuts off.
Once it shuts off immediately hold volume up + power + home. Once you see display on screen stop holding power button but hold the rest.
Once you get into the recovery menu stop holding the other buttons. If you see a green android exclamation mark or no command try pressing volume down + power together for a second to attempt to unhide the menu. A few other combinations you may have to try to get it working if it still does not work.
Use volume up and down to navigate menu, power button to confirm selection.
Do a wipe data / factory reset. Wait for it to completely and reboot phone from recovery menu.
This will take some time to boot up again to the welcome setup screen. Give it 5-10 minutes.
Also to make things easier make sure OEM unlock is enabled before you factory reset the phone.
You can enable OEM unlock in developer options. To show developer options you tap on the build number in settings > about phone 7 times.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
I am unable to do it this way since the brick logo flashes for a small bit before anything happens, also oem unlock doesn't appear to be on my phone.
tarafından
You can force it into download mode by holding Power + Volume down + Home until you get the prompt screen.
tarafından
Yorum Ekle
Yanıtını ekle
Axel Salas sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 831
