Ana içeriğe geç
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
touch not working after battery replacement
Hi,
I have a iPad model A1395 with defect battery. So i replaced with new battery and tried to charge it and it works fine. But then i want to test the touch before i mount the screen back with adhesive... now touch not working and only home-button is working.
Shouldn't the screen work while it's open like iPhone screens when its not completely closed?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
4 Cevap
Filtre ölçütü:
Hello Ibrahim Ibo, If you opened the iPad there are ribbon cables to make the touch sensitivity work i recommend that you reseat the cables inside the iPad then try again if this doesn't work clean the connection then try again.
Hope this helps
-Activoid
Update - the cable should look a little like this
Bu yanıt yardımcı oldu mu?
Puan 0
14 Yorum:
can you please show me picture of this cable?
tarafından
tried to disconnect the cable at both ends, still no responsive :(
tarafından
have you tried cleaning the gold connections on both ends such as the Logic board connections and the ribbon cable connections
tarafından
what can i clean with? 100% alcohol?
tarafından
I wouldn't pour it directly onto the board but put just a tad bit on a cotton ball and just dab it onto it that should work just fine then let it dry for around 15-30 minutes don't wipe it because then you can risk damaging the connections
tarafından
9 tane daha yorum göster
Yorum Ekle
When opening the iPad did you accidentally tear the flex cable for touch glass? Inspect carefully.
If all looks good. Try slowly bending the touch glass around while touching and see if you get a response at a certain bend.
Next make sure the touch flex is properly seated in its connector on the logic board and that no pins were bent
Puan 0
Yorum Ekle
There you go, i taked two pictures. One of the Home button component, and one of the 2-pin over the charger-component
Puan 0
Yorum Ekle
Make sure the cables are not torn or ripped, they can rip pretty easily. If they are damaged purchase a new screen, they're relatively cheep. If they're not damage take the cables out and put them back in again. There is a white line on the cables
make sure the white line is parallel to the plastic screen connector. Also make sure the latch on the screen connector is closed.
Puan 0
Yorum Ekle
Yanıtını ekle
Ibrahim Ibo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 22
Her zaman: 653
