Ana içeriğe geç
Mercedes-Benz W126, 1979-1992 yılları arasında Mercedes-Benz tarafından üretilen bir S-Serisi otomobil serisidir. W116 serisinin halefi olarak Eylül 1979'da piyasaya sürülen W126, Almanca "özel sınıf" anlamına gelen Sonderklasse'nin kısaltması olan bu prestijli unvanı resmi olarak taşıyan ikinci nesildir. W126, sedan modeli için başlangıçta sıralı altı silindirli, V8 ve turboşarjlı dizel motor seçenekleriyle sunuldu. Eylül 1981'de ise C126 2 kapılı coupé versiyonları tanıtıldı.
300SD won't start unless terminal box is shorted
Hi everyone,
I picked up a ragged 1982 300SD over the weekend for a great price. However, the other morning I couldn't get it to start. The starter wasn't turning over, but the car had power and a good battery. I couldn't hear a starter solenoid click either. From my research online and owning a couple of W123s, I tried shorting the two outer terminals of the starter terminal box with the key in the run position and it immediately fired right up.
What part could be going bad? The starter is new from the prior owner, so the only other ideas I could think is that either the neutral safety switch is bad or the ignition switch on the rear of the ignition assembly is bad. Are there any other parts I might want to look at? If all else fails, I'll install a push button start in conjunction with the key, but preferably, I'd like to fix the problem. Thanks!
Bu iyi bir soru mu?
Puan 0
2 Yorum
Do the dashboard indicators light up when you turn the key? I forgot, was the SD a diesel?
tarafından
Yes the indicator lights pop up. The glow plug light comes on for 10 seconds and then shuts off, and the battery light comes on until the car is started. And yes, it's the diesel. The starter sounds very healthy and the car starts up immediately when you short the terminal block.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sounds like you are on track with your diagnosis of neutral or start contacts in key switch. Check for voltage on the start lead when you key the start position (you will need an assistant unless you have very long test leads that will reach into the drivers position). If no voltage try jiggling the shift selector a bit while keying to start position. I would check for voltage at the park/neutral switch (key side of circuit or both if you are not sure) while keying to start position. Still no voltage? .... it is the key switch in all probability and that will be a pain to change out I expect. Maybe a discretely mounted dedicated start button is going to be much easier to do in that case.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Turns out the neutral safety switch is bad. I'll get around to replacing it eventually, but I'll be mounting a push button start in conjunction with the key. Thanks!
tarafından
Yorum Ekle
Yanıtını ekle
Jasen Friedle sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 20
Her zaman: 2,571
