Ana içeriğe geç
Sony Xperia Z4 (Avrupa'da Sony Xperia Z3+ olarak bilinir). 5,20 inç 1080x1920 ekrana, 1,5 GHz işlemciye, 3 GB RAM'e ve 20,7 megapiksel arka kameraya sahip akıllı telefon. 2014 yılında piyasaya sürülmüştür.
My phone does not charge
My phone does not charge or turn on, I connect the charger but it does not start the charge, I put the battery in another phone and it works fine. help please that can be. Thank you
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi!
I think you should replace the charging port. Maybe the IC has gone bad or something. Follow this guide until step16 to see how.
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
I was looking for the same thing, can this part be?
https://www.aliexpress.com/item/T-Parts-...
or it is about another
tarafından Paylaş
Yeah that's it!
tarafından Paylaş
Excellent, I will make the purchase, but most likely it takes 2 months at least to get to Peru, so after that time we will know the result. Thanks for your help.
tarafından Paylaş
Yorum Ekle
Check you power connector maybe its loose or Some dirt inside..
Puan 1
1 Yorum:
the phone does not have more than 4 months of use and I have it saved several months ago because it is broken and now I want to repair it. But I doubt it's dirt. Which part do you think is causing this failure?
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
jhulion sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 23
Her zaman: 2,667
