Ana içeriğe geç
Here are the repair guides for Xiaomi Redmi Note 4X
36 Soru Tümünü görüntüle
Charging the phone after getting wet
My phone got wet a few days ago but it worked fine so I payed no attention and used it normally. But yesterday I plugged it in and it didn't charge. I dissassembled it, I cleaned it, I followed every advice I found in the internet but it still didn't work. But now I tried to plug it using pressure and at some point it started charging. I used a rubber band (:P) and I left it in. I wonder however if I should do it or not. Is there any possibility it breaks down or explodes?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@lefterios you didn't tell us how you cleaned it. If not properly cleaned it will continue to corrode and continue to fail. After proper cleaning you must replace the battery. After that re-evaluate what damage you really have. Right now you will only find yourself replacing parts based on guesses.
Bu yanıt yardımcı oldu mu?
Puan 2
4 Yorum:
Is there a possibility somehing else has damage? Phone works fine
tarafından
@lefterios Did you clean it and replaced the battery?
tarafından
I have ordered the battery and I'm waiting for it
tarafından
The battery wasn't the issue it still doesn't charge. Most probably the charging port is damaged.
tarafından
Yorum Ekle
If inside is clean. I suggest you try replacing your charging port.
Puan 1
1 Yorum:
I'll try that! If you know a trustful site to order it please let me know
tarafından
Yorum Ekle
The first thing I would try is disassemble and soak the main and sub boards in 99.9% alcohol. Leave for an hour or so then look for any corrosion and scrub gently with a soft toothbrush. Allow it to dry thoroughly and reassemble.
I doubt the battery is damaged.
Puan 0
Yorum Ekle
Yanıtını ekle
lefterios sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 2,672
