Ana içeriğe geç
Samsung's flagship phone, the Galaxy S8. Released in April 2017.
Green flickering screen Cracked
My phone is cracked really bad in the front and back. Now it has a permanent greancolor line across the screen.It also had one black spot and i can't see anything behind that spot. When i use my phone a green screen flickers and then covers my entire screen. while this is happening my screen still works, i can feel the vibrations when i touch the screen. Will replacing the screen fix these problems or do i need a new phone?
Bu iyi bir soru mu?
Puan 14
1 Yorum
It worked. Thanks bro
tarafından
Yorum Ekle
6 Cevap
Filtre ölçütü:
Seçilen Çözüm
From my experience the only way to fix this issue is to replace the display, that includes the LCD and Digitizer. I have found this is a fairly complicated repair if you do not know what you are doing and I would recommend getting it repaired by a professional.
Bu yanıt yardımcı oldu mu?
Puan 2
4 Yorum:
Is there any store or phone repair company you know where we could go to? And do you know how much you think it would cost?
tarafından
So why would you say as a repair tech , that his problem could only be solved by replacing the most expensive part , , when he clearly states that it worksmost of time and then quits while typing , mesning theres not a thing wrong with the phone except that it needs a new glass lens \ screen face
Not what is underit that makes the phone operate ! Come on now its still an expensive fix , take them as you get them no need to get over on people good honest 100% truthful business practices and consulting , always end up making more money , than , second hand off the hip guessing , or misinformation ,
For this is what makes a customer not only leave and never return , but tell his friends , all about how , some know it all doofus repair tech.(allegedly) claims my phone needs a new battery , when obviously. Its the fact ive never charged it, on a wall plug , only tried , holding a magnet over the top of it while i heat it in the sun with my magnifying glass,
Idk , why its not having power in battery after that , i mean the magnets get hot , i know becuse i can see it really goid ,
But just no battery power still ,
(Repair tech.)-
Well your gonna need a bigger msgnet thst only i can get you , to start with , if that doesnt work you will need o come back because your mag.glass isnt , weak enough , if its too strong , it heatz the bttery too fast and the electromsgnectic centerfuge you ste supposed to create , wont take a good grip , , so once we get that good , youll only need , a new battery ,
Extended life , and a new led chsrger ,
With a dedicated line in your home as well as your car , to use strivtly for your new , equipment , oh and ill install both of those as well ,
So ,
Ok , !?!?!
Gimme all your money , , !!!!!?🤑🤥🤚
Customer like , -😏
Glad i have you tube !
tarafından
Help I can hear my phone it went red hot I dropped from a low chair ,now it's green then red then nothing but I can see the charging how much is on it in white I can here it it as o very hot 4 nothing just cleaned apart bronchitis plzzz help xx
tarafından
To Phil and anyone else who isn't a mobile repair tech < chill homie, compared to complete new screen im sure it's the cheaper option and anyone else who isn't a mobile repair tech. Depending on model and generation of device replacement of screen should have fixed any and all display issues. In recent years most if not all phones hardware and screen is 1 piece instead of battery and parts on the shell/body. Mainly due to the scarcity of raw materials used in the production of components. This way customers won't have to keep coming back to get replacements and repairs on a device which results in physical troubleshooting sending devices back and forth til the true issue is found. It's a pretty quick way to lose customers due to the complete lack of convenience as well as paying the deductible . But to answer OP's question, yes get a new screen Depending on your insurance situation it's very affordable, mines under warranty so $30 for new screen and its tacked on the bill. Pretty much get a whole new phone.
tarafından
Yorum Ekle
En Yararlı Yanıt
Try cranking up the brightness. Helped me with the flashing green screen
Puan 5
3 Yorum:
Man, u solved my problem in a second. Thanks a lot. I just have a minor crack in s8+ but green light was bothering me. Thanks for the idea.
tarafından
AWESOME tip, thank you!!
tarafından
%#*@, that actually worked
Thanks a lot
tarafından
Yorum Ekle
Get the camera to turn on and the glitch will usually stop. That's how I've been fixing mine
Puan 2
2 Yorum:
Realy helped thanks didnt expext note 10 plus i dont know for how long but looks good green screen is gone i can see now
tarafından
Just worked for my s8. Thanks a lot!
tarafından
Yorum Ekle
The same thing happens to me. I think the only way to fix it is to replace the display. It’s been like this for months, and nothing helps.
Puan 2
Yorum Ekle
My s8 has a very light green screen over almost the full screen. There is a 0.5cm line at the top that isn’t like this. One of my classmates dropped it a few weeks ago and smashed the top corner, I have had this phone for over 2 years and it has been in almost perfect condition. So I think my classmate dropping it is the reason its broke. I was wondering if anyone would have any suggestions on how to fix this? My mum freaked out when the corner smashed and I do not want show her what I’ve done to this phone.
Any help is greatly appreciated
Puan 1
1 Yorum:
Charlotte, did you ever figure this out? My ph did the same thing .
tarafından
Yorum Ekle
I have this same problem but with a s9 would it be cheaper to buy a drifrent phone or stick with repairing it
Puan 0
Yorum Ekle
Yanıtını ekle
Makiya West sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 104
Her zaman: 74,003
