Ana içeriğe geç
Volkswagen Group B5 platformunu temel alan tamamen yeni bir Passat, 1998 yılında Kuzey Amerika'da piyasaya sürüldü.
Car is hard starting
My 2001 Volkswagen Passat 1.8t is hard starting when hot or cold and I have to crank over the engine and turn the key off and try again and again before it will start. When it does start it usually idles really low until it finally catches up to normal.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
This question was migrated from https://meta.ifixit.com/Answers.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Even though it does sound a lot like a Fuel pump/fuel pressure issue. Get your car scanned just in case. Fuel pump won't throw a code though.
When you have the codes and aren't sure, post back here.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Air flow and throttle show a short circuit .wiring okay
tarafından
Yorum Ekle
check your fuel pump in case fuel is not pumping. In case, it's not fuel pump, check the fuel filter if its not that then it is starting sensor. these are the three likely suggestions for the hard starting in VW passat.
Puan 0
Yorum Ekle
Yanıtını ekle
Stephen Ryan Bearden Madison E sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 27
Her zaman: 1,753
