Ana içeriğe geç
The Coolpix S7000 was released in 2015. The camera has 20x wide optical zoom, Wi-Fi capabilities, and Near-Field-Communications (NFC).
Telesccopic lens will not retract on the Coolpix S7000
Telescopic lens will not retract when camera is turned on or off. The entire telescopic lens stays extended.
Error message says "Lens error. Try again after turning the camera off and on".
I have tried to remove the battery, memory stick, turned on off multiple times.
Thank you,
Jeff
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
There are a few simple things you can try documented at https://therestartproject.org/wiki/Compa... but if none of those work then I'm afraid you may be out of luck.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Jeff sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 400
