Laptop won’t turn on at all?
Hi so basically my ASUS laptop died one day and since then won’t turn on at all no matter how much I charge it the lights at the bottom of the laptop turn green and orange but when i press the power button the screen stays black... also as soon as I unplug it from the wall the green light goes off. I have tried removing the battery but it didn’t help at all. Is there anyway I can fix it?
Bu iyi bir soru mu?
Puan
0
when you switch it on, can you see the lights?
Mohit Kumar tarafından
@mojitos Gabriel did mention the lights are on of the laptop itself. But no power light as it won't turn on
@s0larkid if you have the tools required, you could try to open it up and see if the cables for the LCD are connected,
I've had this problem with my Asus T100TA Notebook, but in my case it was because the Windows button was jammed causing it to not boot when I pressed the power button.
Most likely it has nothing to do with your battery though, it could be an issue with connectors or buttons.
Lena Fox tarafından
