Ana içeriğe geç
Psp 3000 display after new motherboard
Hi everyone. I had a bricked psp 3004. I tried every combination which i saw at youtube. Didnt work for me. I found used psp 3004 motherboard and change it. It is ta-090. My bricked motherboard was ta-093 f1001 1.0a . After i power it up with new notherboard, my screen looks like this : https://ibb.co/eVten7 i can see icons on bottom area. But funny lines on screen. What is wrong with my display? Is it display or motherboard problem? Thanks for your help.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi!
Before looking into replacing any component check the connection between the LCD panel and the motherboard. You might have not inserted the screen ribbon cable or the screen power ribbon properly. I suggest that you disconnect the screen and plug it back in. Also while at that, check the screen ribbon cable for damage, anything like small dents and/ or bending signs could damage these fragile ribbon cables.
If you find nothing and reseating all screen connections does not fix your issue, replace the screen.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Comments:
hello @alexniculescu thanks for your reply. I cant see any physical damage on screen or ribbon cable. i try to move screen when it is connected to motherboard. then i disconnect and connect it again. but the pattern
on the screen isnt change a bit. exactly same which i show you at the picture.
tarafından
Well, it looks like you'll have to replace the screen as well. @tunaerkan
tarafından
Yorum Ekle
Yanıtını ekle
Tuna Erkan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 10
Her zaman: 414
