Ana içeriğe geç
Calculator stuck in "On" Position
I took apart a Sharp EL-1197P calculator and cleaned contacts with 91% isopropyl alcohol. When I reassembled it and plugged it back in the power switch was set to off but still turned on. I flipped it back and forth still nothing. Please help!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
you could possibly have a short in the switch, or on another part of the circuit that relates to the power supply. take a multimeter across the leads of the switch to see if you are getting continuity in the off position. if you are, then the switch is faulty and needs to be replaced. if not, you can move on to a bigger scale issue.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
I have no idea how to replace the switch so I'm tossing it and getting another one. Thanks for your reply!
tarafından
Sou técnico de calculadora a 45 anos,este Def está na chave mesmo,tem que limpar melhor com limpa contato e melar o dedo de grafite,tirar o excesso e passar na borracha do seletor
tarafından
Yorum Ekle
Yanıtını ekle
Nick B sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 476
