Lightning port too loose?
Looking for suggestions or similar symptoms to diagnose.
Lightning cables will just not stay in this phone if either is even shifted to the slightest. Unscientific measure; I used to be able to pick up the dropped phone by the cord alone without disconnect. Now ANY pull or pressure and the cord comes out. I don't see any debris in port, but my eyes aren't perfect. I can't tell if there are pressure levers or contacts that I see inside on left and right, and maybe one is bad?
YES, it still connects to laptop.
YES, it still charges fine.
YES, i tried original cable.
YES, i tried a NEW original cable.
YES, the cables 'pop' in/ fully seat.
NO, there is no case.
YES, i tried with a passthrough case.
help?
Bu iyi bir soru mu?
20 Yorum
Worked for me. Thank you. I found that the lightning port was about 25% packed with lint. Pulled it out and now it works.
Tim Stander tarafından
Pretty slick....... thought it was a tech repair or replacement! Just like new!!
Joseph Charbonneau tarafından
I had this happen before I think because I keep it in my pocket. I used a plastic toothpick and out came the lint. Not a ton. Blew in it. Some more came out and finally pulled more out. Don’t think I got it all but same as y’all charging cable in, Apple car play came right up and it’s not slightly loose!!!
Don Curran tarafından
Perfect Solution! Thanks.
James Kirchen tarafından
Boom! That did the trick!
tim milburn tarafından
15 tane daha yorum göster
