Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
DFU mode timeout during software extraction
I'm trying to restore an iPhone 7 that is stuck on the connect to iTunes, but iTunes says there is an error and it can't connect. I tried putting the phone into DFU mode and it connects just fine so I start the restoration process but the iPhone will only stay in DFU mode for about 1 minute before restarting and messing up the restoration. Anyone know how to fix this? Thanks in advance!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
The problem is the iOS file is huge, and it takes too long to download, and DFU mode is impatient.
To fix this issue, first download the iOS IPSW from alink here.
Now, open iTunes and put your phone back into DFU mode.
Instead of straight clicking on the "RESTORE" button,
• on a PC, hold SHIFT, and then click "RESTORE", and select the file you downloaded.
• on a MAC, hold OPTION, and then click "RESTORE", and select the file you downloaded.
This will immediately extract and upload iOS to the phone before it leaves DFU mode.
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
I was able to figure it out. I managed to get the phone in regular recovery mode and restore from there. DFU mode now works normally, so I'm not really sure what the issue was before.
tarafından
Nick rose how did you manage to sort it bud,even tho I've downloaded file without itunes,I'm still timing out at the extracting arghhh
tarafından
Just had the same issue, Restore only updating OS not erasing settings e.g. lock code, so tried DFU mode, iTunes timing out of DFU mode every time during update. Went back to try simple Restore one last time and it magically worked, settings and lock code are now gone, not sure why but happy!
tarafından
Yorum Ekle
You can just disconnect the phone and iTunes will continue download the OS. When it’s done, re-connect, re-enter DFU, and do the restore.
Puan 0
Yorum Ekle
reinstall iTunes, when prompted if you rather: 1 uninstall and reinstall iTunes or 2 repair itunes. Repair itunes then try dfu reset. worked for me
Puan 0
1 Yorum:
iTunes is part of the OS and has been replaced with the Finder for purposes of restore in newer systems anyway. It can not be uninstalled.
tarafından
Yorum Ekle
Yanıtını ekle
Nick Rose sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 33
Her zaman: 9,334
