Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
I bent the battery a bit, is it still safe?
Today I replaced the rear housing on my iPhone 6 as the original was bent and badly dented. However, when I took out the battery, both adhesive strips broke immediately, and I had to heat it up with a hair dryer and peel off the battery. But it was very difficult, and the battery got bent near the top. It wasn't bent very far, maybe 20 to30 degrees. When I was done with replacing the housing I bent the battery back into shape and installed new adhesive strips, and it works fine, it charges, holds a charge well, and shows the percentage. The battery was never punctured or torn, just bent. Is it safe to use or should I buy a new one?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I think it's okay if you don't think it has become bloated or smell anything weird from the battery.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
no, is not,you should change it
Puan 0
Yorum Ekle
Yanıtını ekle
Matthew Sigmond sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 254
