Ana içeriğe geç
Fare, klavye ve monitör gibi çalışması için gereken üçüncül bileşenlerin dışında ana bileşenleri ayrı bir kasada bulunan, sabit, kişisel masaüstü bilgisayar.
Why is it beeeping
The beep code is 1-1-1-1-1-1 th en turns off I've tried removing all the parts and I had a cpu that was the same one I switched th e cpus and still beeps. I know it's not the ram cause I just got the ram 2 days ago. I haven't taken out the cemos yet I'll try that but if anyone knows how to fix I need the awnser.
Bu iyi bir soru mu?
Puan 0
4 Yorum
@mcofficalplays what make and model is your computer? What motherboard is it? Did it have this issue before you replace the memory? Have you tried the old memory
tarafından
@mcofficalplays
list out the make and model as mentioned from oldturkey03
check on your graphic card and power supply also.
tarafından
My computer is the Brodcast pix slate g 1000 i tryed removing the graphics card and I got this without ram but,with the ram type
tarafından
@mcofficalplays try opening up the casing, take pictures of inside mainboard, perhaps install a working graphic card and see if it boots up
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
The broadcast Pix slate G 1000 is not a typical computer. This is a highly customized machine with proprietary hardware for broadcast television video. I suggest posting on their forum for an answer.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
i will post there
tarafından
Yorum Ekle
En Yararlı Yanıt
If you just Google for your brand of motherboard suffixed by "beep codes" you may well find the answer.
Puan 1
1 Yorum:
I can't it's a special motherboard made by the computer company that is the same one that made the computer.( The pc is a switcher)
tarafından
Yorum Ekle
Yanıtını ekle
McOfficialPlayYT sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 179
