Ana içeriğe geç
The fourth generation of Honda Accord covering model years 1990 through 1993 available in coupe, sedan, and wagon chassis.
45 Soru Tümünü görüntüle
I have leakage from my heater valve coil and somewhere else
my honda started running hot took it to auto mechanic, who ran a test with this device attached to the radiator of my car. doing that revealed the leak, was instructed to replace the valve coil heater hose. did that now there's a leak somewhere else close to the original leak please help me figure this out.
puzzled
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Be "car-ful", you are in big-bucks territory. My friend's Jaguar leaked into the passenger carpet, smelling so bad,,, it was parked. Repair was estimated over $2500. Shade-tree mechanic simply coupled the heater in&out hoses together. This eliminated both the hot-water-heater, and the problem. Ah well, the AC works and we live in Arizona, and he still drives it to work.
Your mechanic pressurized the entire cooling system and found only one leak? Generally, a heater hose that old will 'weep' at the end fittings and corrode any metal it finds. Pressurize it again, and find ALL the leaks. Pay extra attention inside the car, when it is at normal engine temperature, run the heater full-blast with the windows rolled up. If you can smell the leak, and the windows get steamy, you have a serious problem with the heater 'core'. If there is no issues inside the cabin, then replace all heater hoses, and the heater control valve.
Hope this helps.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
kelly jones sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 28
