Ana içeriğe geç
Gateway makes quality notebooks, laptops, and netbooks. Owned by Acer Group.
So SSD upgrade in gateway.
Some reason my last post was deleted.
I’ve got a crucial mx500 500GB SSD for my grandpas gateway NV55C laptop. I’ve also upgraded the CPU to a i5 and ram to 8GB. I am running into some problems transferring the old files to the new SSD. On the old drive I click my user and it says “administration permissions” and if I click continue it goes but then stops at the end.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Try doing it while having the computer booted in safe mode.
Use advanced startup options to boot safe mode:
https://www.tenforums.com/tutorials/2294...
This may also help you too:
https://www.tenforums.com/tutorials/3841...
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Better yet, if you are comfortable with Linux, use the live USB of sysreccd or Ubuntu.
Use the command 'rsync -rv --progress <source> <destination>'
Puan 2
2 Yorum:
I think I’ve got it now. It finally opened it up! Last night I started the transfer and I’m going to check it soon. If it transferred correctly all 64GB should be transferred. That’s all I need to do.
I did a clean install of Windows 10 because it had windows 7 and the updates were going crazy.
tarafından
If you transferred into an account folder (i.e. user\documents), and not a root folder, you will likely have a permissions problem, and not see the files on the new computer.
tarafından
Yorum Ekle
Yanıtını ekle
Padraic Hoselton sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 223
