Ana içeriğe geç
2012 yılının sonlarında piyasaya sürülen Asus X55C, 1366x768 ekran çözünürlüğüne sahip 15 inçlik bir dizüstü bilgisayardır. İçerisinde Intel işlemci bulunur ve Intel'in dahili grafik birimini kullanır.
Graphic chip doesn't work
Would it work if I unplug the graphic chip by disconnecting it from the power supply? Would the cpu-integrated graphics - ia intel i3 - work on its own?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @josko
The Intel® HD Graphics 3000/4000 graphics "chip" in your laptop is integrated in the same package as the i3 CPU .
You cannot separate them and as the CPU is probably mounted on the systemboard you cannot easily change the CPU either.
What is the problem with your laptop graphics?
If you have no display what have you checked?
Have you tried connecting an external monitor for example to check if there is a display on it when the laptop is turned on?
If there is an image on the external monitor:
Have you checked the laptop's display, using a torch at an angle close to the screen to check if there is an image there or not? It will be very faint but if it is there you should be able to see it. If there is an image detectable, then you may have a backlight problem.
If there is no image on the laptop screen there may be a problem with the video cable, video cable connections at either the systemboard end or the screen end or the screen itself.
If there is no image on the external monitor either then you have a systemboard problem
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
It appears this laptop has an PGA (or similar) socket, so CPU replacement is possible. There's even a guide for it: Asus X55C Intel CPU Değişimi
This laptop may also have a dGPU. If that is the case one might not be able to replace the GPU as it is often BGA, but using the CPU's integrated graphics are an option.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Jozef Postrak sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 25
Her zaman: 387
