Ana içeriğe geç
Surface Pro 4'ün halefi olarak Haziran 2017'de piyasaya sürülmüştür. Microsoft Surface Pro 12,3" olarak da bilinir. Model numarası: FJT-00001.
Heat Gun/Blower for Screen Replacement
I am looking at purchasing a heat/gun blower to replace my Surface pro 5 screen (warm the adhesive to weaken it)....as well as for other electronics.
I have come across 3-in-1 Function Heat Blower and Soldering Iron (see link below), which I thought could be helpful with other projects also.
https://www.jaycar.co.nz/3-in-1-function...
Has anyone had any experience using this type of "heat blower"? First thought is it may be difficult to control the temperature...although it does have a flame adjustment setting.
Thanks in advance for your help.
Bu iyi bir soru mu?
Puan 1
2 Yorum
Hi @dgmossman ,
You may wish to take note of the warning at Step.1 in the ifixit Microsoft Surface Pro 5 ekran değişimi guide.
Just a thought.
tarafından
Go for an iopener, otherwise it's too easy to damage the surface.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I think the soldering gun you picked will be to narrow an area and far to hot to do the job well. I believe you chances or success on this repair would be much greater with a standard heat gun:
Heat Gun
Loosen adhesive or reflow solder with this 1500W heat gun. Low setting reaches 570 degrees F (300 degrees C). High setting reaches 1112 degrees F (600 degrees C). Görseli
Ürün
Heat Gun
$29.99
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
I would use the iOpener or a heatmat.
Puan 2
Yorum Ekle
Yanıtını ekle
Daniel Mossman sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 26
Her zaman: 1,723
