Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
Home Button Not Working Even After Replacement
Hello,
I have a iphone 5s whos home button has stopped working, i have got 2 replacements and tried both of them and neither have worked. my next idea would be to change the charging port, but im not sure if that would do the job so asking you guys if you have any ideas.
Thank you
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum
I mean, if it's not the actual button itself, or the cable connecting the button to the board, it's probably the board the button is connected to yeah. Though you sure it's the charging port?
tarafından
well the home button connects to the charging port so its possible, i need to get the part to test it to be sure though. i have a funny feeling its a logic board issue to be honest. just thought i would throw the question out there just in case :)
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Is it the actual button? Or the ribbon? If its the ribbon, you may as well get a whole new phone as that is non fixable unless you want to buy a new logic board to have installed which is about the price of a new one.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
are you referring to the home button ribbon? i know the home button is able to be replaced, you just loose the touch ID functionality which it already doesn't have for a while anyway as the home button was already replaced about 6 months ago
tarafından
The ribbon (one attached to the logic board) if ripped or damaged is impossible to replace unless replacing the entire board
tarafından
We repair torn home button ribbons in my store.
tarafından
Yorum Ekle
Aftermarket homebuttons will work, however it will disable Touch ID functionality.
Puan 1
3 Yorum:
That is true the Touch ID will not function.
tarafından
ive tried that already too, not bothered about Touch ID
tarafından
Then your issue is more than likely in the charging port. Not the home buttons.
tarafından
Yorum Ekle
This is more than likely the charging port flex connector to the home button replace that and should work no problem.
Puan 0
Yorum Ekle
if you have the orginal home button on there its probably the connector, circuit board, or software glitch.
If you have a aftermarket home button it will not work. It has to be an Apple home button which you could get a Apple but they have to install it. Or just disable the home button and use the accessibility buttons on the screen as your home button.
Puan 0
2 Yorum:
it is A original apple home button but not THE original button. its already been replaced once and worked for a good 6 months now its not working again. have 2 other original buttons but neither work
tarafından
From my understanding the home button Touch ID needs to be reprogrammed if you replace it with an original apple home button which you can only get from Apple store and they have to install.
tarafından
Yorum Ekle
Yanıtını ekle
James sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 32
Her zaman: 2,393
