Ana içeriğe geç
The tenth generation Ford F-Series is a line of pickup trucks that was produced by Ford Motor Company, it was sold from the 1997 to the 2004 model years.
83 Soru Tümünü görüntüle
Why does my 1999 f150 lose all electrical power and engine dies.
My 1999 F150, auto, 4.6 V8 loses all electrical power and the engine dies. It starts up again but the same thing happens again later. This has been going on for about a month but recently it is happening more often. Died three time this morning. So far it seems to happen when slowing down like to stop. I have maintained this vehicle, it only has 116,000 miles and in good condition. Do you have any suggestions?
Thanks,
Bu iyi bir soru mu?
Puan 1
2 Yorum
I have read about the IAC but would it also shut down all of the electrical (gauges, lights, radio etc.)? It acts as if you had turned the key off and everything goes dead.
tarafından
@cabranch47 you've checked the battery and the cables? Checked your fuse box for loose connections or corrosion?
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
My mechanic did find some vacuum leaks and fixed those. He replaced the battery (thought that it might have some internal intermittent defect). So far this seems to have fixed the problem, no issues since Friday. Might be a while before I can trust it but so far so good. Thanks for the input.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
My 2005 did the same thing until it died and didn’t start back up. It was the alternator going bad the whole time.
tarafından
Yorum Ekle
En Yararlı Yanıt
Just to be clear, i’m not a car expert at all, just sometimes an issue jogs my memory :)
To me it sounds like you’re having trouble with the IAC (the intake air controller). It’s supposed to regulate the air intake when the engine will go to idle rpm (which it does when going towards a stop). When it fails to do this properly, the engine stops, and everything with it.
It can get polluted and fail to control, so getting it looked at might not be a bad thing. It’s just a hunch though, so take it as a pointer only.
Puan 2
1 Yorum:
Hi i have a problem that started just a week ago. I have a 99 f150 and it started to shake and wont advance and then it turns off. I have to let it rest for 10 minutes and starts fine and drives fine. Then it starts again trembling and wont advanced
tarafından
Yorum Ekle
I have the same truck and has the same problem.. ones Day I drove to the part store and when I came out of the store.. you got it! No power, no start.. I had it towed home.. after countless hours of research I found that on the driver side in the side kick panel there was a ground wire covered in rust.. I cut the wire and added a price of wire to it and found a better place to ground it and it started right up! Hope this helps.. oh also the ground wire near the fuse box may need to be fixed as well! Good luck!
Puan 1
Yorum Ekle
Yanıtını ekle
Charles Branch sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 9
Son 30 gün: 33
Her zaman: 2,015
