Valve adjustment 1999 ford mustang 3.8l
Valve adjustment procedure
Bu iyi bir soru mu?
Jay Devin there is no valve adjustment on this engine, you just torque the rockers down. First tighten all the bolts to 44 lb/in then do it again at 26 lb/ft
Bu yanıt yardımcı oldu mu?
@oldturkey03 what's the max speed of this pony?
unmodified it has a speed limiter at 115mph-118mph
Is the torque spec regardless of valve position?
fullerals yes it is
This should quiet noisy lifters ?
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 2,576
2 Yorum
I have a 95 ford mustang with a 3.8 but the engine is a obd 2 like a 96 the car is 94/95 . Original engine and transmission no swap and been done I'm trying to find the timing and how to tighten the rocker arms is there a sequence in the firing order to it.. appreciate any help I can get I've been three years working on this and I can't seem to get the timing right ..
Victor Rivera tarafından
Jay I have a convertible Mustang 2004 v6 3.8 motor what is the Valve adjustment procedure? Thank you
Roy Salvatierra tarafından
