Ana içeriğe geç
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Soru Tümünü görüntüle
New replacement battery not charging
Just replaced the battery with Item code: IF161-105-4
MagSafe charging cable is green, battery came with 62% charge. Down to 61% because I unplugged for a bit to test. I did PRAM and SMC resets.
Here is CoconutBattery info:
  • Manufacturer: Simplo
  • Manufacture Date: 2018-03-12
  • Age: 39 days
  • Load Cycles: 0
  • Serial Number: D861015004NDGDL3T
  • macOS battery Status: Good
  • Temp: 27.1 C
  • Battery failure: none
  • Power Adapter: 85W
  • Charging with: 0 W
  • Power adapter: Connected
Bu iyi bir soru mu?
Puan 0
2 Yorum
@davidmatthew did this solve the problem?
tarafından
I am getting the same issue again.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I misread the SMC reset directions. Make sure you press all of these keys for 10 seconds when MacBook Pro is shutdown
Shift - Control - Option - AND Power button ;). Battery is charging with 16.48 watts
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
I have the same battery detailed above. Did the same key sequence for SMC reset and still the same issue. Went recently to a Apple Genius Bar for a full diagnostics and the result was an issue with the battery. Before the issue happened I just charged the battery a couple of times (right now has cycle count = 7 and battery status = good)
tarafından
Yorum Ekle
Yanıtını ekle
David sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 1,502
