Ana içeriğe geç
Huawei'nin 2017 amiral gemisi akıllı telefonu. Mart 2017'de piyasaya sürüldü. Unibody gövdeye ve Leica ile ortaklaşa geliştirilen çift arka kamera kurulumuna sahiptir. 32/64 GB depolama seçenekleri ve altı farklı renk seçeneğiyle gelir. Model numaraları: VTR-L09, VTR-L29, VTR-AL00, VTR-TL00.
Fingerprint sensor is overheating
Hello. I own a Huawei p10 and recently it fell out of my pocket and landed on its screen. Luckily it had its cover on and got a scratch on the upper left corner. Everything seems to be working fine until later on the day I noticed that the fingerprint sensor (glass) was unusually hot. I didn't notice it before but are finger print sensors warm to touch? Also the finger print sensor is working fine, it responds as default and a also enrolled a new fingerprint ID just to see if it's working, and it did. So anyone can tell me it will be okay or am I just worrying too much? Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 6
3 Yorum
I have this problem too.
This problem showed 3-4 days ago.
Fingerprint senosr area i very hot when i just use my phone normaly.
I instal CPU-Z and my soc_thermal was 52C.
Do you fix a problem?
tarafından
The fingerprint sensor is still hot but it hasn't affected my phones performance. I am still using it normally and I don't think opening the phone right now would be a good option.
tarafından
I am in the same situation,. The fingerprint sensor is burning hot after a sudden fall. Luckily no scratches in the front screen. But the sensor has a bit in the mid back portion. Service centers are more than miles away from our province. Already restarted but the fingerprint sensor is not working it just work for on and of now. Hope it won't cause anymore trouble.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I say don't worry.
Others might disagree
I know on iPhones the Fingerprint sensor is directly above the charging port so the charging port is overheating,
In your case (I don't know where the sensor is to be fair), try rebooting it, and see if no other component is causing the overheating.
If it gets worse over time, replace the component that causes the overheating,
or take it to a repair shop.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thank you :)
tarafından
Yorum Ekle
My phone also fell out of my poket and the screen was slightly cracked, fingerprint scanner didn’t work anymore but mostly, the area of the sensor got very hot.
While the phone was still very much usable, except for the fingerprints, the battery life was very short due to the constant heating. It would not even last a day on a full charge while not being used much.
I brought the phone to a repair center where they swapped the whole display assembly. (glass, LCD, fingerprint sensor) Now it works perfectly fine again and the battery life is also good (~2days).
I hope this helps
Puan 0
2 Yorum:
Is the fingerprint sensor still hot/warm to touch after the replacement? Thank you for the response.
tarafından
But the phone is that still under warranty? Because currently I have faced same problem and already reboot the phone so many times and even reset the factory set.
tarafından
Yorum Ekle
Yanıtını ekle
ali arif sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 31
Her zaman: 13,238
