Ana içeriğe geç
Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794 Soru Tümünü görüntüle
No battery power, no charging after replacing battery
MacBook Pro 2010. I replaced the battery with the one I received from ifixit. The computer booted.
Two weeks later, there’s no power. The battery indicator shows no lights. If I connect the power supply, it’s light remains green. With the power supply connected, the machine boots but if I disconnect it, it loses all power. Also, with the power connected, the battery indicator blinks all lights five times when the button is pressed.
The battery indicator icon shows 100% charge but also says replace battery. I’m attaching a coconut battery screenshot.
I performed an SMC reset.
What should I do? Any chance to receive a replacement for the brand new battery I purchased from ifixit?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
4 Yorum
This just happened to me! I bought a replacement battery from macbookbatteries.com awhile back and I couldn't replace it at first because the screws were stripped. This morning I swapped out the battery and plugged in the power adapter to charge it. When I saw it go from orange to green I powered on my MBP and the indicator showed it was charged 100%
A few minutes later the notice appeared saying the battery was at 2%.
I plugged it in again, and within 10 min the indicator went from orange to green again.
I heard horror stories about buying batteries from Amazon but apparently they're not the only ones to be wary of.
(correction: first version said I got the battery from ifixit, but I was mistaken)
I'm disappointed in this battery and plan to request a replacement.
tarafından
What OS X are you running and did this start after your last system update? @danj
tarafından
@mayer - I'm running 10.13.4 currently, I haven't updated my systems yet. That's one of this weekends chores.
tarafından
@danj I am only running into problems with machines that have had third party hard drives or batteries installed.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
There is the possibility the the MagSafe charging port has lost functionality. Even though it is still able to power in the computer, there could be an issue with it, hence why the battery will not charge. It’s most likely caused by a false load coming from the MagSafe port. Hope this helps!
Bu yanıt yardımcı oldu mu?
Puan 1
4 Yorum:
OK, I’ll try another charger. This one used to work though and there’s no power without the connection. The battery shows as 100% charged when the laptop boots (with charger power).
tarafından
The port I’m taking about is the port on the inside of the computer itself.
tarafından
This would be way above my qualification
tarafından
@aaandre - @ellispctech is talking about the comparator logic which compares the voltage between the MagSafe and the Battery it controls the switching of the power between the sources and load.
tarafından
Yorum Ekle
It seems as the chargers power is routing straight to the main power and you battery is failing you to some degree. What I recommend if you can, try and buy a new receiver for the battery and solder it on the mother board. If you cannot do that then buy a new motherboard and use your old battery.
Puan 0
Yorum Ekle
Yanıtını ekle
andrew andreev sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 224
