Ana içeriğe geç
Alcatel One Touch Idol 3, 1,5 GHz işlemciyle desteklenen 5,5 inç, 1080 x 1920 bir ekrana sahiptir. Haziran 2015'te piyasaya sürülmüştür. 6045Y, 6045K, 6045O, 6045I modelleri mevcuttur.
Why does phone gong instead of ring?
I have an Alcatel One Touch Idol 3. Occasionally, instead of ringing like it should (using the ringtone I selected as default) the phone just gongs slowly. It particularly happens when my son calls (I have no idea why). The problem is that the gonging sound is quite low in volume, and I almost always hear it too late to answer in time. Does anyone else have this problem, and if so, how can I fix it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Hi Joe,
Has the gonging ever happened when someone other than your son called?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
If the ring tone only makes that sound when your son calls and with no one else , then it sounds like you or your son set the ring tone to that sound. You can set different ring tones to each individual contact. All you have to do is go to your son's contact, click edit, scroll down to were it shows ringtone, and then change it or set it back to default.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
I already checked that. The ringtone was set to default.
Puan 0
Yorum Ekle
Yanıtını ekle
Joe Perrone sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 321
