Ana içeriğe geç
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
Press home button to upgrade (broken home button)
Hello
I googled everything & everywhere but couldn't find an answer.
I have iPhone 7 Plus stuck at press home to upgrade screen, home button is broken. I tried pressing power + Volume down. Then tried connecting iTunes, that says enter passcode on phone to connect. Latest iOS.
Advise a solution please. Reply soon.
If this button is repairable or not?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 42
5 Yorum
IPHONE 6 Plus upgraded IOS from 9 to 12 and I was presented with "Press Home Button to Upgrade" and my Home button had not been working for some time. Did have AssistiveTouch virtual Home Button but that was not responding. This worked for me as I had read another article where it had worked. I cleaned my home button with vinegar and an ear bud as I didn't have any isopropyl alcohol. Tried my Home Button again, didn't immediately work so I kept clicking on the Home Button in a circular motion then the Pass-code screen appeared for the very first time. Entered my code and the upgrade completed successfully.
I know this wont work for everybody but it might help, I had spent several days trying all sorts of given solutions including software tools. I have turned on automatic updates now so hopefully I wont need the physical Home Button again.
tarafından
not working on my phone
tarafından
i have a iphone 6 and missing home button so i use a gidget witch lets me press home, but i did a update and got this screen and it wont let me touch the screen to use the gidget so yea.
i dont even care about most things on my phone, i just need my minecraft worlds and battle cats recovery code.
edit: is there a way to do it without factory resetting it?
my computer wont recognise that my phone is plugged in to it
tarafından
worked for me.....thanks a lot........
tarafından
I had the same issue and after holding down power off and volume down, my phone makes a really loud high pitched beep. Its honestly not scaring me so can someone tell me why tis is happening?
tarafından
Yorum Ekle
36 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I FOUND THE FIX! After a successful update or restore, plug the device into itunes, then set up as new ipad. Go to accessibility, then put voice over on. This will allow you to double click the “press home to open” and continue the setup process!
Bu yanıt yardımcı oldu mu?
Puan 33
22 Yorum:
You genius. This should be marked as the top answer. The other answer tells you how to get assisitive touch but you can't bypass the upgrade screen to go to the settings. I would advise people to reset the phone first though (hold power and vol down button until the screen says connect to itunes). Please upvote this answer everyone.
tarafından
I'd like to say thank to you.. managed to get into home screen after restore using Voice Over.
tarafından
I have iPhone 6 with broken home button After done updating, my phone was stucked at Press Home to Upgrade. I've plugged into iTunes but nothing happened. What can I do?
tarafından
My iTunes isn’t recognizing the phone. It did before, and it does my other phone. But since this “Press home to upgrade” came up, iTunes does nothing.
Help!
tarafından
@clevelandh did you get to fix it? I have the same situation here. My iTunes asks me to enter the passcode on iphone to connect with it but all I have is the white screen. How to restore my iphone again?
tarafından
17 tane daha yorum göster
Yorum Ekle
I manage to resolve the problem :)
  1. conect the Iphone with i-tunes
  2. Press power + Volume down and hold it until i-tunes will recognize Iphone and ask you to restore or update Iphone
  3. I press restore and i-tunes start to dawnload the software
  4. After finish the dawnload I press power + volumen down again and hold it until again i-tunes asked you the same question .. figure 2
  5. Click restore and i-tunes will start to restore your Iphone to factory settings
  6. Once done, asked me again to press home button - “Hello - press home button to continue” (which doesn’t work) so I switch phone off and turn it on again… then I manage to set it like new Iphone
  7. Once done this set HOME BUTTON on TOUCHSCREEN -> go to Settings - General > Accessibility , Scroll down to the section labeled INTERACTION and tap on AssistiveTouch (ON) .
Puan 8
6 Yorum:
That's what I said in my post lol.
tarafından
i connect my iphone with itunes but itunes cant detect my phone. how i going to follow your solution?
tarafından
I’ve just done that and it’s asking me to check if iTunes Is updated on the phone but how can I check if I can’t get into the phone
tarafından
You have to make sure A.) if using WIndows PC, your USB drivers are all up to date usually done in Windows Update automatically, but go to control panel/hardware & devices/Device Manager/USB *right click/update drivers B.) you're using a MFi cert. or original Apple cable (some work some don't) C.) your version of iTunes is completely up to date; if once you've done this, you're still not recognizing the phone connection in iTunes, follow the restore process for your particular device and unfortunately, you'll end up having to restore the device and if your data isn't saved in the cloud or a recent backup in iTunes hasn't been done, you're SOL as far as your personal data goes. However, the restore process when finished will prompt the screen in iTunes that either a.) requires your activation lock info to proceed or b.) Set up as new iPhone or Restore from Backup (if any are available it'll list backups available). At this point, you can Set up as New iPhone.
tarafından
BTW I tried this method... several times... it did not work for me. Every time I try to power off and on, it comes back to "press home to setup". However, the Set up as new iphone once restore process is complete, go to bottom of screen and click on Accessibility Options in iTunes. Turn on Voice Over. Then triple tap the top middle of the screen and it bypasses the need for pressing home button. And, one more thing, you'll wanna turn OFF automatic updates if on because this will keep happening to you the next time it does an update that requires press home button to continue after update is installed. So you're gonna wanna get used to updating through iTunes and even backup via iTunes occasionally in addition to the cloud.
tarafından
1 tane daha yorum göster
Yorum Ekle
I had the same problem and finally figured it out.
# Have the phone on
  1. Plug it into your computer with iTunes open.
  2. Press and hold the volume down button
  3. While doing step 3 press and hold the power button.
  4. Once screen is black keep holding the volume down button yet let go of the power button.
  5. The computer should recognize the devise within 10 seconds.
  6. Update using iTunes.
Puan 5
5 Yorum:
My home button is bad and when I put in my password it goes to a white screen showing"press home to recover" and my assistive touch is not working on that screen
tarafından
nope doesn't work but thx
tarafından
thanks!!! Funciono correctamente! Saludos desde Argentina
tarafından
iphone recovery mode appeared on itunes! tysm! TRY THIS YALL
tarafından
This guy is AWESOME THANKS AGAIN
tarafından
Yorum Ekle
if you can go into settings go to general, then accessabilty, then assistive touch and turn it on and it should give you an on screen home button
Puan 4
7 Yorum:
Problem is that the phone was updated probably via iTunes with passcode enabled.
Only way to get around that with a broken home button is to restore the phone resulting in user data on the phone getting wiped.
tarafından
dependent on ios could a non original home button not be used to get past that
tarafından
@benjamen50
Thanks for help. Can you pls explain how to restore it? I can't bypass "press home button to upgrade". Will be much appreciated.
Yes, actually i bought it yesterday and tried to update it from a backup thru iTunes.
tarafından
@tech_ni thanks daniel. I can't really pass the screen "press home to upgrade". If I can bypass that, I can even live with assistive touch. Someone sold to me yesterday claiming that it can be replaced in $100.
tarafından
Download 3Utools from 3u.com, install then open it.
Plug iPhone in. Go to Flash & JB Tab, select flash and keep user data unchecked. It'll download firmware then once it's downloaded restore your phone to you to latest iOS version.
Image here: http://prntscr.com/jbkfqg
tarafından
2 tane daha yorum göster
Yorum Ekle
The home button it's self is not generally repairable.
Is this after a screen replacement?
Puan 4
6 Yorum:
I was transferring a backup of old iPhone through iTunes and ended up "press home to upgrade" screen. Before that, button was broken but I was able to use through assisted touch. Do you have any clue please?
tarafından
Are you saying that you need to press the home button but you can't as it's broken and that you can't use assistive touch because it's not active?
If so then try clicking the power button 5 times quickly, then press cancel, this may or may not help, or try someone else's screen with home button so it actives the assistant home button.
tarafından
It didn't work. :(
tarafından
Maybe best to use some one else's screen and home button then so you can turn the assistive touch on then.
tarafından
My home button does not work after a screen replacement. They said I need to update my software in order for it to work again, is that true?
tarafından
Yorum Ekle
If none of this helps and you’re still stuck on press home to upgrade, try to just remove the sim card than put another sim in, it will take you to wifi setting to activate your phone. From there you can set up as normal.
Puan 3
3 Yorum:
Does the phone have to be powered off or on?
tarafından
Thanks a million,, this worked perfectly for me 5 stars friend
tarafından
damnn!!!! you are a hero. Thanks a lot!!!
tarafından
Yorum Ekle
You can buy this handy device that acts as an external home button. I’ve used that lifesaver to bypass “press home to upgrade” on iPhones that have broken home buttons. From there on you can just use AssistiveTouch as an on-screen home button. Or, you can keep using the adapter as your home button in the future if you wish.
Puan 2
4 Yorum:
thanks I bought one of these adapters and I was able to get past "press home to upgrade" with it
tarafından
I bought one of those and it hasn’t worked did u fix the problem?
tarafından
Does this external home work for iPhone 6 plus' running ios 12?
tarafından
i tried this device , but i doesn't work at all , and one more thing , the assistive touch is there but it doesn't work as well ((((
tarafından
Yorum Ekle
If you are restoring your phone from a backup & you have a home buttong issue, do the following; Before you backup up the phone enable voice over through the accessibility menu.
The assistive touch option does not work when you are stuck on the press home to upgrade screen. The voice over option allowed me to click on the home to upgrade then double tap to continue. Worked for me.
Puan 2
Yorum Ekle
For those who don’t know how to restore your iPhone to allow yourself to put on Voice Over to bypass the “Press home button to upgrade”.
Plug your iPhone to iTunes and try that way, if it requires that the iPhone be unlocked you can download Reiboot and from there you can manually restore and update it from your computer. When you restore it, it will say “press home to open”. You are going to hold the lock button to restart your phone. After you restart it, it will bypass that screen. then set up as new iPhone/iPad on your computer. Go to accessibility, then put voice over on. This will allow you to double click the “press home to open” and continue the setup process!
Puan 1
Yorum Ekle
I gave up. I was stuck in “upgrade…” white screen and my home button wasn’t working. Also, reiboot or itunes couldn’t identify my phone. I went to an alternative repair store and they enforced DFU with a little machine pluged in my phone. I forgot the name. They didnt even charged me.
Puan 1
2 Yorum:
Glad you eventually got it fixed, though it must have been a frustrating procedure.
tarafından
Really can’t stress enough the value of using an Apple cable to connect. I tried everyone of these suggestions multiple times but nothing worked to I scrounged up the lightning to usb connector that came with the device
tarafından
Yorum Ekle
Turn off iPhone. When turning on, connect to computer, it will open iPhone recovery mode on iTunes, and let you update or restore iPhone. the screen on iPhone will change from "press home to upgrade" to iTunes logo
Puan 0
1 Yorum:
pressing power + Volume down when turning on and connect to iTunes. Didn't work the update, but it restored to original settings.
tarafından
Yorum Ekle
If there's no important data on it, restore it, once that's done you can click on the iPhone logo, pass the “get started" screen so the iPhone storage and everything pops up, you can turn on the voice option and unlock it from there, tap once on the “press home button to unlock" then double tap it. That's how I got passed it on my iPhone 7. Restored to blank then set up afterwards. Maybe upload your backup to the cloud so you can just use it after? Just don't let the phone timeout and you'll be fine. My first choice was to turn on assistive touch.
Puan 0
Yorum Ekle
I have had the same problem. I have an after market screen with a broken home button. When attempting a software update, it prompts you to press HOME button after it powers back on but doesn’t allow you to use the Assistive Touch (virtual home button) or touch screen, leaving you with major anxiety.
I was able to press power button and volume down while plugging into computer… THEN passcode comes up but you still can’t use touch screen, so I hit power button to clear / refresh the screen and WALLAH, suddenly Assistive Touch was enabled after screen refreshed and then I was able to enter passcode and continue finishing update.
A serious pain but this method works for me on my Apple iphone 7 plus.
Puan 0
1 Yorum:
You're saying you just pressed the power button to turn the screen on and off and then it worked?
tarafından
Yorum Ekle
ebay sell iphone 7/8 (JC version 3 home button ) which works via bluetooth but needs small bridge fitted,,,there is also a final version which doesnt need bluetooth or the bridge fitted
Puan 0
Yorum Ekle
I have problem with my iphone 6s , my screen shows “press home to upgrade’’ and my home button dont work , i tried literally everything , itunes and reiboot app cant recognize my iphone . nothing helps , please help me ;(
Puan 0
3 Yorum:
I'm also have problem with my iphone 6 , my screen shows “press home to upgrade’’ and my home button dont work. if you already get the solution please share...thx
tarafından
Me too. Its unbelieveble.
tarafından
Same it makes no sense but my phone just got traded in, I LITERALLY couldnt do anything!
tarafından
Yorum Ekle
U will need to get a home button that plugs in. I used this one: https://www.amazon.com/MaximalPower-iPho...
Puan 0
Yorum Ekle
I have also same problem with my iphone 6, my screen shows “press home to upgrade’’ and my home button dont work, i tried literally everything, if someone already have solution, please share, thx
Puan 0
Yorum Ekle
Hi Guys, I managed to make my iPhone 7 work again from the “Press Home to Upgrade” screen while the home button is broken. I tried many times with the restoration and update so I’m not sure how it happened and not sure the steps below will 100% work for you.
I have a Mac running OS X 10.15.4 and an iPhone 7. iTunes is no longer with the latest OS X . So, I used Finder to do all these steps.
Here is what I did:
  1. Plug iPhone (showing “Press Home to Upgrade” ) to the Mac
  2. Long Hold Volume Down & Power Buttons-> iPhone will be shown in Folder which means the iPhone is in Recovery Mode
  3. In Finder -> Select iPhone -> Update (I’m not quite sure if I updated the phone successfully or not)
  4. Put the phone in Recovery Mode again -> Open Finder -> Select iPhone -> Restore iPhone to the Original Settings and Latest iOS
  5. After “Restore” -> Turn on the phone -> Finder -> iPhone -> Configure Accessibility -> Use Voice Over -> Now you can double tap the words to “slide to open” your iPhone.
  6. In Finder -> Backups -> Restore Backup
  7. After “Restore Backup” you should see the setup screen like factory reset, but not the “Press Home to Upgrade” screen, and the Voice Over and Assitive Touch are still there, and the data is restored back the phone.
Hope it helps.
Puan 0
Yorum Ekle
hello sir please to help me my phone can’t press button home because press home to upgrade.
I hope that you can help me.
Puan 0
Yorum Ekle
Hi everyone. I had the same problem with an iphone 6 that had a home button that wasn’t working. I downloaded and installed ReiBoot. Launched the app, plugged in the phone that was stuck at the ‘click home to upgrade screen’; clicked on ‘enter recovery mode’' and boom! Just like that the phone entered recovery mode. After that the phone was recognised by my Mac and I updated the iOs and after it was done I then used a backup I had made on my Mac prior to the factory reset and restored the phone which installed all apps and data.
Puan 0
1 Yorum:
how do you click “enter recovery mode”? I have an iphone 5 and can’t enter recovery mode without pressing the home button... Reiboot still doesn’t recognize the device
tarafından
Yorum Ekle
You need to make a backup of your phone to iTunes with the screen home button activated. When you use this backup you will see the screen home button active when it asks you to press home button, just press the screen home button and away you go. If you haven’t got a backup log someone else’s phone into your account and make a backup from that one after activating the screen home button, you can of course use your own backup to that phone activate screen home button and resave, of course making sure your mates was backed up first.
Puan 0
Yorum Ekle
I have an iphone 6s and I BROKE my home button and henmy dad finds out he kill me and ho to fix it. download the itunes on your computer on ipad and it should ask you to plug it on your computer than it will show this black box around the press home button to upgrade click it and BWOOM but mines wont let me do it.and your welcome!
Puan 0
Yorum Ekle
You are presented with the “press home to upgrade” screen. When you plug the phone into Itunes it isn’t recognized because you have a password. To get around this, you must put the phone in recovery mode & set it up as a new phone without a password. Then connect phone to itunes & restore a backup you had from before.
Puan 0
Yorum Ekle
I managed to solve the problem for my iphone with a broken home button. I think it has something to do with the OS of your mac, it has to be a higher/updated OS for iOS 14.3 to work. Unfortunately, I backed up my data into a macOS Mojave. And it still kept going to the white screen even after updating software & restoring to factory settings.
SOLUTION #1: Update your OS
You can update your OS (mine worked on Catalina). The process of backup & restore will no longer be under “Music” previously known as iTunes. You’ll now back it up via Finder. You’ll see your iphone at the sidebar once you connect it with your USB cable.
or if this method takes too long, here’s how I did it.
SOLUTION #2: Borrow someone else’s mac with a higher OS (I used Catalina).
  1. On your iPhone, From the white screen, press your Sleep/Wake button + Volume Down button and long hold. The iphone will turn off and turn back on. Keep holding until you come to the Recovery Screen then let go. It should show you a diagram to connect to laptop via cable. (This takes a few tries)
  2. Connect your iPhone to the mac via USB cable. It won’t show up in “Music” app (previously iTunes) so don’t go there. You will find your iPhone in Finder sidebar with an eject sign next to it.
  3. Click on your iPhone at the side bar. It will prompt you to either Update Or Restore - Choose Restore.
  4. The phone will reset and will start at the “Hello” screen - Set up your iphone as a new iphone.
  5. Return to your own mac (mine was Mojave) and locate your backup files in your Finder.
  6. Click on Finder>Go>Go To Folder… OR Finder>command+shift+G
  7. Type in this: ~/Library/Application Support/MobileSync/Backup
  8. Choose your backup (named with a bunch of letters and numbers - Right click>Get Info to see the date and time it was created)
  9. Copy the folder to an external drive/pendrive
  10. Go over to the higher OS Mac, repeat steps 6-7 and paste your backup folder in there.
  11. Now replug your reseted iPhone into the higher OS Mac again, and click on it at the Finder sidebar.
  12. You will now have the option to restore your backup. The newly copied backup should show up.
  13. Back that bugger up. And vuala you’re done.
Puan 0
Yorum Ekle
i fixed it on my mini2
when press home button for upgrade appears the assistive touch is unresponsive
press n hold power button and volume down until restart
press homebutton for upgrade reappears keep on clicking the power button multiple times the passcode screen should appear
Puan 0
Yorum Ekle
  • My I phone press home to upgrade
Update (06/06/2021)
My iPhone problem
  • Press home upgrade
Puan 0
1 Yorum:
Press Home to upgrade
tarafından
Yorum Ekle
Do you know the virtual home key on the iPhone? it can be round like on iphone 12, or square like on iphone 7. But I'm in trouble, I give the phone to my grandson to play, he pressed a few places, did disappear a virtual home button. Now, how to make the Home button reappear, for convenience and use? Give me some suggestions
Shop the best eyeshadow palettes now at Fashion Mentions. These eye shadow palettes throughout our makeup-wearing careers, and these are the ones that we always reach for.
Puan 0
Yorum Ekle
SOLVED!
Date: 02/09/2021
My devices: iMac mid-2015 in macOS Big Sur. iPhone 8 with working TouchID but Home Button broken.
Managed to get through DFU and setup as new device, yet failed to restore from an old backup, stuck at the “press home button to upgrade” screen.  Tried several times with enabling either VoiceOver or Assistive Touch before restoring backup, yet all failed.  I BINGO by disabling both TouchID and passcode to unlock the phone, no more “press home button to upgrade” screen after all, got all data saved.
Here is the walkthrough:
  1. connect the iPhone to Mac.
  2. Press and release of Volume Up button, then press and release of Volume Down button.  Press and hold the Power button, you will see power off and back on, release when you see Recovery Mode screen.  (a cable pointed to a mac)
  3. On Mac side, Finder should prompt update or restore your iPhone.  Click restore, it started downloading Firmware automatically, which brings iPhone back to factory default.
  4. After restarting, setup as new device.  (As my iPhone had assistive touch enabled here, no problem get through the Hello screen).
  5. Go to Setting > Touch ID & Passcode, uncheck (use Touch ID for) iPhone unlock, then Turn Passcode Off.
  6. Back to Finder, Location > your iPhone,  hit Restore Backup under General section.
  7. After restoring backup finished, no “press home button to upgrade” screen this time, direct me to Hello screen with Assistive Touch enabled.
  8. You know what to do.
I hope it helps.
Puan 0
Yorum Ekle
Please upgrade my phone
Puan 0
Yorum Ekle
Hi everybody! I had the same problem with my iphone 6 and a broken home button. My iphone storage is full and I want to reset it. I've done a backup on itunes and about to restore it. The first "hello welcome" screen requires a home button to continue. I managed to get past it using 3utools to add assistivetouch via accessibility settings. While restore process is running, I left it. At that time I made a passcode lock and when I came back, the screen was stuck on the "Press home button to upgrade". I couldn't press the assistivetouch that was there. After searching and doing various ways on the internet, I managed to solve it by flashing recovery mode (idk what it calls) and repeating the process restore without adding passcode. You can do flash recovery mode via reiboot but it is paid and I did it via 3utools for free.
Puan 0
Yorum Ekle
Hi i have been try everything to find solution and i find that a good app. The idea to already pair with bluetooth on iPhone 7p or above iPhone than connect it through android app ,,the name of app bluetooth and keyboard mouse
so it can use touch and home button and more than button.
So before update we have to way to activate .
1.active voice over.
Or
2.use android app through android phone to connect iPhone by bluetooth to controller the iPhone,,, name of app apk bluetooth and keyboard mouse i put image of the app i tried 2 way and i have been activated my iPhone 7p
On the ios 15.6 update.
If any questions for help connect me through my number 00967773388755 WhatsApp
Puan 0
2 Yorum:
If can't do the tow way above then just update until the phone start up the passcode appear automatically by it self like my iphone7p did, then enter your password the go manually activation the assistive home button
tarafından
The problem that ask press to update<broken home button it because the i restored old backup or wrong backup i don't sure what exactly then it asked me to press to update i search everything and i read every post in this site ifixit so i can't press the home because it's broken and not activated the assistive home button so finally i restore my iphone7p and delete everything and connect with iTunes and select as a new phone. And everything goes great and started use the iPhone again so in future in case if I want to update or something wrong with backup i will activate the assistive home button or use android phone to controller touch and home button by this app ,,bluetooth and keyboard mouse [image|2709690]
tarafından
Yorum Ekle
back to my iphone plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
Puan 0
Yorum Ekle
plzzzzzzz
my iphone plzzzzzzzzzzzzzzzzzzzzzz god
Puan 0
Yorum Ekle
What can i do, my iphone says press home to recover but home button not working?
Puan 0
Yorum Ekle
I don't know the I cloud and also I don't know the password... So please help me
Puan 0
1 Yorum:
not possible
tarafından
Yorum Ekle
lol what worked for me is using the back of a pen to jam the home button down with all my weight. Had to wiggle the pen around and push down on different corners of the home button but it worked.
Puan 0
Yorum Ekle
Yanıtını ekle
ihtxami sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 42
Son 30 gün: 182
Her zaman: 149,160
