Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
Touch is not working. Missing a voltage?
Hello all,
More of a technical question... I have an iPhone 6 with no touch. Before lifting cumulus I was poking around for voltages and am missing PP5V1_GRAPE_VDDH. There is no short to ground on that line.
I pulled U1501 and replaced it with one I had on a doaner board that might have been bad. I lost all image on the screen but had backlight after that.
Retracing my steps, I reballed the original U1501 an stuck it back on and the phone is back to how it was.
Should I order and install a new U1501 or is there something else you would advise me to check first?
Thanks all and happy repairing!
Joseph
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
did you try meson to see if it could be an issue
Bu yanıt yardımcı oldu mu?
Puan 2
28 Yorum:
Honestly no I have not. Before pulling it off I thought I would check voltages going to the two.
If it were an ip6+ they for sure first thing would be an M1 jumper. But in this case, no stress on the board seems to make any difference in it working, so I was leaning away from classic touch diseases (also being a 6 not a 6 plus) are there some inputs I should test out for menson? Or what would you recommend I do to it?
tarafından
cumulus and meson have connected lines like CUMULUS_TO_MESON_VSTM_OUT_N, CUMULUS_TO_MESON_VSTM_OUT_P, CUMULUS_TO_SAGE_BOOST_CLK_EN, TOUCH_I2C_SCL, TOUCH_I2C_SDA
tarafından
also did you check resistance on j2401
tarafından
I didn't check resistances on j2401, somehow that passed my mind .... Surprised. That could easily tell me what it might be.
Is it normal for U1501 to have 2 of the 3 power outputs OK and the third dead? That's my primary thought on this one at the moment. I don't have the schematics here with me at home, butbinkimda thought that they would all be present, or none.
tarafından
I will definitely check those lines though on Monday
tarafından
23 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Joseph Hughes sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 566
