Ana içeriğe geç
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
773 Soru Tümünü görüntüle
Will the serial number of my MacBook Pro change?
I have two MacBook pros that are the same model. One of them is water damaged and the logic board was affected. If I swapped out the logic boards would the serial numbers also be swapped?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Yes the serial number is stored on the logic board if you want to keep serial number tied programs as much as I hate to say this as your not fixing it yourself take it to a third party repair store they might be able to repair the water damage and if they can't ask them about switching the chip that stores the serial number on it
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
You'd be much better off to try and repair the main board rather than buying a super expensive replacement. I'd say send it to a place like the one in my bio for repair cost is usually between 199 and 299 with 400 being the max for most board repair specialists. If it is unfixable, then it would be way cheaper for Apple to service it then replacing the board.
Puan 1
Yorum Ekle
Yanıtını ekle
Sam Quinn sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 1,876
