Ana içeriğe geç
Xbox error codes
Does anyone have a cut-sheet for Xbox 360 Pro or later with error codes, problems, and their solutions? I am new to 360's and am looking for any information available. I am aware of Iprep 101 but have not used it. Any information would be helpful.
Also, I am very experienced with repairing iPods - so I'm happy to share my experience with anyone - just ask.
Thanks,
Kelly
Bu iyi bir soru mu?
Puan 4
5 Yorum
Thank you Brian.
tarafından
Accept Brian's answer if it answers the question!
tarafından
Brian's answer was better than nothing and has been helpful. Darn Interns! LOL
tarafından
There is an Accept answer button on Brian's answer. If this answered the question, you should select it to give him credit. Also, try to keep answers away from email, and here on the site, so everyone can benefit. Thanks!
tarafından
sedric, thanks for your help. I will give Brian the credit - still learning the process. However, I want to use my email for documents not for answers. But good advise as well.
tarafından
Yorum Ekle
6 Cevap
Filtre ölçütü:
Seçilen Çözüm
A quick search turned up this sheet which seems fairly comprehensive.
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
Firstly error codes follow the link below its pretty comprehensive.
http://www.llamma.com/xbox360/repair/Xbo...
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
Firstly try a new AV cable. Secondly the Hana or ANA chip does sometimes develop dry joints, taking a thin tipped soldering iron to the pins of the device is the only solution to that. If its the graphics chip causing the error you could either try the X-clamp solution (google it) or you could try getting it re-flowed... whatever you do dont wrap your 360 up in a towel or take a paintstripper heatgun to it in order to try and reflow the graphics chip (You will damage the chip internally if you do so ;) ) Easy way to tell if your graphics chip is at fault is to open up your 360 and apply downward pressure to the graphics chip when turning on your 360.
Best of Luck
Justin
ConsoleFixers.com
Puan 1
Yorum Ekle
I hope REpair dudes aren,t using this website to blackmail family owned video stores.
Puan 0
Yorum Ekle
Does anyone know about the E74 error code for Xbox, and how to fix it?
Puan 0
Yorum Ekle
huawei network line err u8950d
Puan 0
Yorum Ekle
This came super late but it is verifiably the most accurate error code table.
https://repair.wiki/w/Xbox_360
Puan 0
Yorum Ekle
Yanıtını ekle
aquabluekt sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 12
Her zaman: 10,673
