iPhone 6s Plus unresponsive
Got the 6s+ on trade from a friend and she said the screen needed a replacement (no cracks on screen and don’t look like it’s been damaged). She threw it on the ground out of anger and the phone it’s self bent slightly (seen worse that still worked) on the logic board (right) side of the phone. I’ve left the phone on the charger for about 45 minutes and didn’t get any activity. Did a basic inspection for simple damages and considering the phones only 2 moths old it’s still basically new. The charger port checks out and is the cleanest I’ve seen one in a long time, taking the screen off to check the internals and everything looks nearly normal. The battery took shape of the bend with the housing and the logic board the same but not enough to effect anything, with experience with bent phones I’m running out of solutions. However the welds for the heat shield for the RAM are broke. (above SIM card and below screen connectors)
Apple A8 APL1011 SoC + Elpida 1GB LPDDR3 RAM
I believe the actual part (listed above) under the heat shield wouldn’t have been harmed. But I guess I’m asking if the RAM could’ve took enough damage to cause failure.
Thanks for anyone with a solution or advice I appreciate it greatly and if you have a question of would like pictures let me know
Edit by benjamen50, reason: added images for OP
Bu iyi bir soru mu?
1 Yorum
Bent logic board caused cracking and fried components. [image|1444738][image|1444750]
dajangoh tarafından
