Ana içeriğe geç
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 Soru Tümünü görüntüle
Display Backlight not working after replacement.
So I replaced the display assembly (thanks for the great tutorial), and it worked fine for 2 days but it suddenly stopped working, after some debugging I noticed that if I shine a light behind the Apple logo the screen can be seen correctly and if I connect and external monitor it works great. I've read it my be a fuse, cable or conector but I'm not sure how to test them. My board is 820-3787-06.
Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
11 Yorum
If you need a closer lookup of any part just tell me :)
tarafından
FWIW the old screen worked before (it had damage) I connected it right now and it has the backlight problem too.
tarafından
Tried a PRAM reset? If not, then could be a blown backlight fuse any history liquid damage drop damage? If you need board level repair, I can always help you out peep bio for that, but first thing is to try a PRAM reset.
tarafından
I've done PRAM and SMC reset it didn't help. It was liquid damage
tarafından
Sounds like a board problem then. Unless you have a bad screen, but if the old one is doing it, then I'd go backlight problem
tarafından
6 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
This shows the location of the backlight fuse. Check it with a multimeter. Should measure 0 to 1 ohm. If it doesn't, you're looking at a logic board replacement and/or component level repair.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Ok so yesterday I investigated a little more, and using the datasheet I just uploaded:
Fuse F7700: Continuity OK
U7701 EN: 3.29V
U7701 PWM: 3.27
PPBUS_SW_LCD_BKLT_PW: 11.58V
BLKT_SD: 11.42V
LCD_BKT_EN_L: 11.4V
C7726: 5V
BKL_SW: 0
BKL_FB: 0
BKL_FET_CNTL: 0
PPBUS_SW_BKL: 0V
PPVOUT_S0_LCDBKLT: 0V <---- I know this should be 55V!
tarafından
I think either it's Backlight Driver (U7701) or Transistor(Q7706)
tarafından
Yorum Ekle
LCD_BKT_EN_L: 11.4V is enable … so ist Must be 0v for Turn on
Puan 0
Yorum Ekle
Yanıtını ekle
Adrian Rangel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 274
