Ana içeriğe geç
Harley-Davidson Sportster Motorcycles from 1986 to Present.
34 Soru Tümünü görüntüle
The motor cycle dies after about 30 seconds
i have a 95 sportster battery is showing 12.5v and a full tank of premium fuel , the bike starts and runs for about 30 sec and dies, i can see the gas spraying but the bike won`t stay running
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
If it is a carburettor than most likely it is the idle circuit. Take a look at your filter, is the fuel running through that OK? You might need to pull your carb and give it a thorough clean.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
This sounds like a gas issue , has it been sitting up ? I would check carb , It may be gunk up from sitting with gas in it , if this helps you great , if not reply
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
also check fuel flow , it can also be not flowing good , (check for TANK TRASH if flow is not good)
tarafından
It sat over the winter on a battery tender and had it tuned up before winter, well I took the tank off to paint it which all I dissconnected was the crossover fuel hose that leads from obe side of the tank to the other and the 2 fuel hoses on the petcock I took the petcock off to paint, well when I put it back on the bike and start it, it only runs for about 15-30 seconds I see the fuel spraying in the carb
tarafından
Yorum Ekle
Yanıtını ekle
chris clayton sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 15
Son 30 gün: 39
Her zaman: 1,865
