Showing error 80 while shooting video and now not working
While video shooting showing error 80
Bu iyi bir soru mu?
Bu iyi bir soru mu?
My buddy is in the same boat with his 70D so Ive been doing some digging trying to find him a solution. It would appear there is a "kind of sort of home remedy" but it requires the camera to at least turn on and be functional at some level. If you can get it to turn on again you can try setting it to record for a set period of time and take continuous snapshots. This may allow the chip that has broken its solder connections to reheat to the point the solder essentially reflows itself.
The only other home remedy I can think of would be to pull the logic board completely out of the frame and apply significant heat directly to the affected chip. You'll need access to a hotair rework station in order to achieve the temps needed to reflow the solder but even this is not going to be a proper fix. Just like with the xbox 360's, this will be a temporary fix at best.
Bu yanıt yardımcı oldu mu?
Canon 70D camera is not turn on
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 750
