Ana içeriğe geç
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Soru Tümünü görüntüle
How to turn off phone without screen? I do NOT want to restart.
My boss wants me to turn off his iPhone. His screen is broken, so he cannot slide the slider to do so. A hard reset or restarting does not fix the problem. I do not know why he wants it turned off or why that matters, but that is what I need to be possible. Is there any way to do this without just draining the battery all of the way? I don't need to reboot, and I don't need to do a hard reset, I need to do a hard reset, I need the phone to turn off and then not turn back on afterward. I saw a suggestion online saying to hold the home and power button and let go right when it turns black, but this does not seem to work, as the phone still restarts.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 6
2 Yorum
For my iphone 6s plus, if I release the power + home button after the apple logo, then it shuts down. Now if you don't have a screen obviously you won't know when to release. For me it was around 15-20 seconds from when I started the long press, you could try and get lucky.
tarafından
Thank you worked the very first try.
tarafından
Yorum Ekle
11 Cevap
Filtre ölçütü:
En Yararlı Yanıt
i had the same problem when my touch screen stopped working but i found that hold in the volume up, volume down and lock button at the same time it tuns off and stays off.
Bu yanıt yardımcı oldu mu?
Puan 7
1 Yorum:
my iPhone XS tries to call emergency services when I press and hold power + volume up + volume down. buttons.
tarafından
Yorum Ekle
Inspired by @revelle but slightly different technique worked on my iPhone X:
Up volume, immediate release. Down volume, immediate release. Continuously hold down power button and don't let go. When the screen goes black, hold the volume up button ALONG WITH the power button until you see the Apple logo AND it disappears.
Puan 6
3 Yorum:
Perfect! this was the only advice that worked for my 12 Pro Max
tarafından
This one worked for the iphone 6
tarafından
this was freaking awesome and the only advice on this whole thread that worked for iPhone XR! thank you!!!!!!!!!!
tarafından
Yorum Ekle
If you hold the power button and the volume button simultaneously, the iphone resets and restarts.
If you immediately hold them both again, it turns off.
Credit to /u/imthatappleguy on reddit, frustrating how many wrong answers were out there!
Puan 5
4 Yorum:
The one and only right answer
tarafından
Helpful !!!!!!!!!!! THANK YOU
tarafından
Good job combating misinformation and wrong answers on this issue. Respect.
tarafından
my iPhone XS tries to call emergency services when I press and hold power + volume. buttons.
tarafından
Yorum Ekle
Your best bet is to probably just wait for it to die. I read the same thing about using the buttons and it seems like your just holding it for too long. Try it again and report back. If not you just need to wait until it dies.
Puan 0
Yorum Ekle
Open the phone and disconnect the battery, then reconnect and screw it back together.
Puan 0
Yorum Ekle
For the iPhone 7, holding down the power and both volume buttons worked. I made the mistake of charging up my old iPhone which had alarms set and a broken screen, and it kept waking me up at 2am.
Puan 0
Yorum Ekle
In my case I needed to hold the power button, volume down and home to turn it off completely.
Puan 0
1 Yorum:
This worked for me.
tarafından
Yorum Ekle
All of the solutions I have seen only help with resetting the iPhone, which briefly turns the phone off, but it always automatically starts back up.
If you want to turn your phone off and LEAVE it off without ability to swipe:
Settings>Accessibility>Voice Control>Set up Voice Control>Shut down Screen>Tap Slider> say “Swipe Right”
Puan 0
Yorum Ekle
  • Hold all 4 buttons down
  • Once u see apple icon on screen
  • Press n hold all 4 buttons
  • Again u see apple icon on screen
  • The screen should have turned
Puan 0
Yorum Ekle
For anyone still struggling, I’ve turned it off this way:
a) press volume up, volume down and power button in a quick sequence to force restart the phone.
b) once the phone is about to boot up and you see the Apple logo, press the power button (only) to shut the phone down.
I’m an owner of an iPhone X. Hope this helps!
Puan 0
Yorum Ekle
hold lock and volume down buttons, after phone shuts off, press them both again but dont hold. just did it and it worked
Puan 0
Yorum Ekle
Yanıtını ekle
Robert Hare sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 52
Son 7 gün: 292
Son 30 gün: 1,857
Her zaman: 59,194
