Ana içeriğe geç
Resmi olarak Chevrolet C/K olarak adlandırılan C/K, General Motors tarafından üretilen ve Chevrolet ve GMC markaları altında pazarlanan bir kamyon serisidir. C/K serisi; kamyonetleri, orta hizmet tipi ve ağır hizmet tipi kamyonları içerir.
Very difficult to move in reverse gear.
The truck will shift through all forward gears just fine without any trouble, but when I put it into reverse I have to give it probably around 3000 rpm to move at all. Trans needs serviced bad. Just wondering if that's my issue or if I have something more to worry about. 1992 Chevy c1500 5.7L automatic 4x2.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
Once in a while I can get lucky and get it in reverse but I can't count on it
tarafından
If I can get it in reverse it will not move and occasionally it's almost like it's stuck in gear
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
If your trans needs a service bad, it might be failing. I'm not sure how many miles you have and how you maintain the car, but by the sound of it, it might be slipping in reverse, so you would need to get a new trans, or get your old one rebuilt. Both are expensive unless you can find one in a junkyard for a good price.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
It is probably the transmission/torque converter. I had the same problem with a prior car...it would lose power in reverse. Quickly shifting into neutral and back to reverse made it work momentarily.
tarafından
Yorum Ekle
Yanıtını ekle
Cole Custer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 25
Her zaman: 1,320
