Ana içeriğe geç
Repair information and disassembly guides for laptops manufactured by Haier.
haier laptop have some performance issues .
MY haier laptop have some performance issues . it was working too slow and after few days it was not open up showing black screen after logo . what to do now?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
11 Yorum
Hi
I have Hair Y11c laptop
Since last night when i turn on my laptop it starts very smoothly but doesn't open desktop i think it needs new window . any one help me what should i do and how ?
tarafından
Hi @mufliha ,
Connect an external monitor to the laptop and check if the display is OK on it.
If there is no display on it either then you have a faulty motherboard.
If there is a display on the external monitor, try shining a torch at an angle close to the laptop screen to check if you can detect a display (with the laptop switched on) at all. It will be very faint so try this in a darkened room. It may help.
If you cannot detect a display on the laptop, then you have either a faulty display panel,or a faulty or loose video cable between the motherboard and the display.
If you can detect a display when using the torch then you have a backlight problem. This could be either a faulty backlight power supply on the motherboard, a faulty video cable, video cable connection at either end - motherboard or display or a faulty display panel.
tarafından
Haier laptop is display problem
tarafından
hi when i click on any icon from desktop or local disk it delete this file and send to recycle bin i again install the window 10 pro 1903 version but problem cant solve please help me
tarafından
tarafından
6 tane daha yorum göster
Yorum Ekle
6 Cevap
Filtre ölçütü:
En Yararlı Yanıt
That is a hard issue to walk someone through on a message board. Off the top of my head I would say manually pull hard drive and use another computer (I use a hard drive dock station as long as it is a sata connection and not an ata) to copy documents and media you don't want to lose. Then you are going to have to erase the Hard Drive and re-image the OS to the Hard Drive and make it bootable using a bootable usb. Then you will still have to figure out how to activate the OS (different depending on what version of windows you have/want). If you are familiar with bootable usb's and Linux OS's then you can try and run Ubuntu (or other Linux OS) on usb drive to diagnose the internal hard drive before pulling and re-imaging. That requires a little more computer "know-how".
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
Keep in mind this is only if the problem is the OS on the Hard Drive (failing or possibly missing or corrupt setup files/packets). The reason I think the problem is in the hard drive is because you said it is showing a black screen after the logo. That tells me that it is before or during bootup but that the hardware components are working to keep the laptop on. Again this is me going off the limited info you have provided and sort-of taking a shot in the dark. Also, the these suggestions are somewhat technical and if you do not know how I would recommend taking it to a professional.
tarafından
at first when i bought my laptop it battery performance was very perfect but since last night i keep my laptop on sleep mode and in the morning the battery was dead so i charged it again but its battery timing is not good enough ..so what should i do should i change my battery or it can be repair ??
tarafından
My laptop external drive stop working that is present in keyboard and keyboard also not working ..
Help me if any one know please
tarafından
Yorum Ekle
Thinking a little more about your problem I think you may want to check that the cpu fan is working first (is there an over heating problem?). They are usually pretty cheap and relatively easy to replace in comparison to the hard drive.
Puan 0
1 Yorum:
how to check if cpu fan is working or not?
tarafından
Yorum Ekle
I have y11b and its mother board is damaged
Puan 0
4 Yorum:
Haier y11c Laptop becomes too much heated from below side after some time.. why?
tarafından
I have Haier laptop, model y11c
Jb ma on krti hun to half screen white hoti ha and half clear hoti ha
Please help me out
tarafından
LCD ka msla hai..mera bhi yehi msla tha me ne warranty claim ki..aur LCD replace hone ky bd ab thk hai.
tarafından
tarafından
Yorum Ekle
recover your windows
Puan 0
Yorum Ekle
not showing the screen
Puan 0
1 Yorum:
please solwo the eshwos
tarafından
Yorum Ekle
A little more observations would help. Does it have a disk activity LED. If so what does it do after the logo disappears.
Here is what happens:
On power up the computer reads and executes the BIOS. The BIOS displays the logo and tells the CPU how to read the boot sector of the drive. If it can't read that nothing happens but it will display a message. If it reads it, it will load the OS. The disk activity LED will blink rapidly and constantly until it is complete.
If it never boots up, the possibilities are that the drive is not functional or that it is not readable because of file corruption. The fact that it was slow before this happened strongly point to a problem with the drive.
You can try doing a repair install of Windows. If that doesn't work, it is time for a new drive.
If you have a backup of your stuff, great. If you have a recent image of the drive, it is painless.
Otherwise, if you connect the drive to another computer externally and the computer sees it you may be able to retrieve your stuff.
Puan 0
Yorum Ekle
Yanıtını ekle
ushra ahmed sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 4,745
